Two Request for [GTS]
erdogankr06
Post by erdogankr06 »
Hello friends,
I would love to convert the two interfaces of the Amazfit GTS 3 to the Amazfit GTS model, but I do not have the knowledge and skills to do so.
If anyone can translate these two watch faces to the amazfit GTS models, I would be very grateful.
Thanks in advance..
Link 1= https://amazfitwatchfaces.com/gts/view/9673
Link2= https://amazfitwatchfaces.com/gts/view/9648
Been thanked: 2092 times
erdogankr06 wrote: 12 Sep 2022, 12:47
Hello friends,
Thanks in advance..
Link1=https://amazfitwatchfaces.com/gts/view/9673
I'm interested to help you in link2
Image Image
GTS no have UV element so this watchface change to Weather icon.
Link1 :
Ultar_copy_EN_packed_zip.bin
(333.01 KiB) Downloaded 39 times
Ultar_copy_RU_packed_zip.bin
(333.47 KiB) Downloaded 33 times
Link2:
Mega_packed_zip.bin
(254.03 KiB) Downloaded 39 times
note :
erdogankr06
thank you so much asoo, i really appreciate your work. When you have free time, can you convert the watchface in link 1 to GTS? I want it too. Thanks in advance.
erdogankr06 wrote: 13 Sep 2022, 05:16
I don't follow the request in the 1st link, it's not that I don't have time to do it. But because I see that the format is similar to your old request. And I think you should try to rebuilt the request from the old work you've requested. so i don't do it.
Let's say this time I will make But next time if I see that the request has a format similar to or the same as the original request. I ask permission not to do it.
You can download your request ( link 2 ) in this :
viewtopic.php?p=13709#p13709
erdogankr06
asoo wrote: 13 Sep 2022, 06:30
thank you for not hurting me and fulfilling my request asoo, take care of yourself.
