Black Manuel Angel's MA Digital Total GTR2
- Has thanked: 205 times
- Been thanked: 5 times
- Contatta:
Hello, can someone who have time and knowledge help me and convert this watchface exactly as it is for GTR2. I have already take permission from the owner.
The watchface processed to black from AEIOU and original watchface is from Manuel Angel. https://amazfitwatchfaces.com/gtr/view/18934
https://amazfitwatchfaces.com/gtr/view/26383 https://amazfitwatchfaces.com/gtr/view/26390
- Has thanked: 441 times
- Contatta:
amazfitfacesafrica ha scritto: 09 ago 2022, 18:40Spoiler
Topic " Black Manuel Angel's MA Digital Total GTR2 "
Change icon color " DND , Alarm , Lock " is White
note :
- Contatta:
Amazing work and thank you for the watchface, it's perfect, sorry it's my mistake but it's possible to make the date ddmmyy instead mmddyy. It's my fault because I didn't notice the date. Thank you anyway whether do it or no.
- Contatta:
Change format Date "DD-MM-YYYY"amazfitfacesafrica ha scritto: 10 ago 2022, 09:55Amazing work and thank you for the watchface, it's perfect, sorry it's my mistake but it's possible to make the date ddmmyy instead mmddyy. It's my fault because I didn't notice the date. Thank you anyway whether do it or no.
viewtopic.php?p=13421#p13421
- Contatta:
Thank you so much for the date fix and thanks to AEIOU and to Manuel Angel for this amazing watchface.
- Contatta:
The icons of alarm, dnd and lock when is on don't became white as it should but it's gray, only connection icon became gray when is disconnected and became white when is connected. Can dnd, lock and alarm icons be white when is s on? You can see in preview what I say. If it's not possible due limitations leave it as it is. Thank you and sorry for the inconvenience.
- Contatta:
Change color " DND , Alarm , Lock " is whiteamazfitfacesafrica ha scritto: 10 ago 2022, 12:57The icons of alarm, dnd and lock when is on don't became white as it should but it's gray, only connection icon became gray when is disconnected and became white when is connected. Can dnd, lock and alarm icons be white when is s on? You can see in preview what I say. If it's not possible due limitations leave it as it is. Thank you and sorry for the inconvenience.
- Contatta:
Thank you, you are amazing, it's perfect.
