Hi guys, i always looking for comic watchfaces because i like them and i found this amazing watchface from asoo with big fonts for easy visibility for my eyes. It would be great if someone with knowledge could convert it for GTR2 in blue without moon phases and instead SpO2 because GTR2 don't support it put humidity and instead PAI put UV. Thank you so much the forum fot they great job they done. Greetings.
https://amazfitwatchfaces.com/gtr/view/24115
G219MOD convert GTR2
SleepyHollow
- Has thanked: 30 times
- Been thanked: 2 times
- Has thanked: 441 times
SleepyHollow wrote: 03 Aug 2022, 12:19Spoiler
note :
SleepyHollow
You are amazing, thank you, everything is works fine except dot distance missing, can you fix dot missing in distance?
Fixed :SleepyHollow wrote: 05 Aug 2022, 00:21You are amazing, thank you, everything is works fine except dot distance missing, can you fix dot missing in distance?
viewtopic.php?p=13376#p13376
