Long 'seconds' image gets cropped when passing through other elements
Post by 4313543 »
I made this watchface: https://amazfitwatchfaces.com/bip/view/?id=15384
I wanted to have the cursor on the bottom blink. I figured I could achieve this by making long images for the seconds digits, taking advantage of transparency, if you get what I'm saying?
So the seconds digits images looked something like:
             _
     12:43:2|4|
With even numbers the cursor is on, odd numbers off. Unfortunately I realized that the images get cropped before it reaches the next line, maybe because it's passing through other elements?
Can anyone think of a way to get the cursor to blink while still keeping the clock in the top line?
TXK
Has thanked: 150 times
Been thanked: 99 times
Post by TXK »
Image for the seconds digits, height can not exceed 24 pixels.
If it exceeds 24 pixels, it will be cut by the watch system。
Moreover, it must be the same line as time, otherwise, it will clear the other images on the same line
(But,background images will not be clear)
TXK
Post by TXK »
Https://amazfitwatchfaces.com/bip/view/21915
Sorry, the number in seconds is still not supported to be higher than 24 pixels.
However, you can use the second hand to refresh the large number of seconds.
