Watchface not applying/crashing?
Moderatori: asoo, Watchmens
sunyi9911
Messaggio da sunyi9911 »
Hello everyone, Im very new to creation of watch faces and before this, Ive only edited the background of watchfaces but not the complications.
I tried to heavily modify one of the watch faces I had, everything looks fine on the amazfit watch face editor 2 tool, it transfers fine, but when it comes to applying it, it will auto revert to the stock face instead of this custom one. I have compiled, decompiled, recompiled to see any issues with the images but no luck. I need help solving this issue. Watch is the GTR 2e.
Allegati
omnitrixFix.bin
(879.77 KiB) Scaricato 78 volte
ben10v2_packed.bin
(437.58 KiB) Scaricato 70 volte
Has thanked: 419 times
Been thanked: 2105 times
Messaggio da asoo »
First of all let me tell you that I don't have GTR2e so I can only check the scritp and resource section.
from the inspection I can't find any abnormality in script "json".
but in resource images look like you use compress png
Since the device has a specific png format, it may result in the image that you compress. The device maybe unreadable.
I recommend using a normal PNG image that doesn't have compress.
The PNG I am using has the following format:
Examples that have been uncompress png
viewtopic.php?p=12996#p12996
I am not sure it's can fixed your issue or not , Because I don't have real device for test.
But if it's work , your issue is "compress png "
sunyi9911
I've narrowed it down to the AOD, the image I have set to it will cause it to not function. I've also looked into the png problem
This is the settings I use to export the pictures, I don't see much difference though. So far, if I don't have anything set as the AOD, it will work but I'm still confused why only the AOD
Messaggio da asoo »
Let's You try to add "time" in AOD.
If I'm not mistaken In the GTR2 main screen, if there is no time section The watchface sometime , It will not be able to be activated. But I'm not sure if this will affect AOD as well.
ben10v2_packed_packed.bin
(430.87 KiB) Scaricato 76 volte
sunyi9911
Oh thank you, adding the time to AOD did make the watch face work. I will now keep this in mind for future projects
