The new T Rex 2 [T-Rex 2]
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
ward3636
Contactar:
Mensaje por ward3636 »
How can I get watch faces like the one's for T rex pro, I got the new T Rex 2 and I can't find any watch faces, just the one's on the Zepp app, help my email address is [email protected], anybody can make watch face for the new T Rex 2, let me know, thanks
Avatar de Usuario
Has thanked: 441 times
Been thanked: 2142 times
Contactar:
Mensaje por asoo »
I am not sure , but you maybe use "GTR 3 watch face" on your T-rex 2. Because Editor official on web zepp show support device in the editor as follows .
Support Device:Amazfit GTR 3,Amazfit T-Rex 2
But i am not sure it work or not because I do not have T-Rex 2 for test
Imagen
File example made form Editor official on web zepp for T-Rex 2
SampleT-rex2.zip
(809.74 KiB) Descargado 335 veces
Yzord
Contactar:
Mensaje por Yzord »
I also would like to know if the T-rex 2 will be supported, because i have issues with the app and my T-rex 2
dbarber1
Contactar:
Mensaje por dbarber1 »
There is a way to install custom watch faces on the T-Rex 2. I asked Amazefit on Facebook about people making custom faces for it and their reply back was that they have an open source option in the works but no date on when it will be available and made a post on Reddit to let others know about it. Someone suggested an app to try that has watchfaces for the GTR 3 and has a direct sync option that may work. I chose one of the GTR 3 watch faces and had it direct sync to the watch, and it worked just fine. I just did it this morning, so I have no idea if they're any negative effects, but it seemed to work fine. It also detects the watch as a T-Rex 2 as well, and transfer of the watchface to the watch doesn't take too long at all. It's not a huge amount of watchfaces and as far as I can tell you can't direct sync watch face files, but for now it will work until a better solution is found.
Here is the link to the app that was suggested to me on Reddit, which worked for me
https://play.google.com/store/apps/deta ... fitwatches
Detcom
Contactar:
Mensaje por Detcom »
I tried to use amazefitwatches app didn’t helped me. Got a T Rex 2 too
Detcom
Contactar:
dbarber1 escribió: 29 Jun 2022, 21:30
It’s working with GTR 3 faces!
So anyway… can anyone remake a face from T-Rex Pro to a GTR 3? 😅
eagerly
Contactar:
Mensaje por eagerly »
working! thanks!
Responder
Volver a “Watchfaces discussion”
¿Quién está conectado?
