One request for [GTS]
erdogankr06
Post by erdogankr06 »
Hello friends,
The watch faces I have given the link below belong to the amazfit GTS 3 model.
I want to adapt these watch faces to the amazfit GTS model, but I do not have the knowledge and skills for this.
If you can make these dials for the amazfit GTS, I would be very grateful. Thank you very much. Good day :)
Link: https://amazfitwatchfaces.com/gts/view/8582
Has thanked: 441 times
Been thanked: 2142 times
I recommend if that work you request to be edit or modify. It is a work on this web. Please informing the owner of the work about you want to bring his work to edit or modify. Before post requesting to modify that work.
That would be great for the owner and the interested person to edit that work for you.
erdogankr06
asoo wrote: 11 May 2022, 15:39
I informed the owner of the work about this. Let's I'm getting. I will return to you.
erdogankr06
hello, I got permission from the person who made the watch interface. I would be very happy if you convert the watchface to GTS model. Thanks in advance.
ALL function work same as original , But no have AOD because GTS not support
Nike_GTS_packed_zip.bin
(263.76 KiB) Downloaded 35 times
note :
erdogankr06
asoo wrote: 12 May 2022, 08:57
thank you so much. works perfectly
