Please Help! Sunset GTR3 Pro for GTR2
Reglas del Foro
- alexstam78
- Has thanked: 173 times
Hello to community, can anyone from the creators port this watchface exactly the same for GTR2. Thank you to all and to community for the hospitality. https://amazfitwatchfaces.com/gtr/view/23007
- Has thanked: 437 times
- Been thanked: 2141 times
- Contactar:
- alexstam78
Yes I know this but it's very changed from original, I don't like the color and the changes it has. It's overloaded. Thank you for the suggestion.
kotobuki09
- Has thanked: 13 times
- Been thanked: 2 times
- Contactar:
I create this version but it's only for GTR3 and GTR3 Pro only. Not sure how to convert to GTR2 though
- alexstam78
Thank you for Info, maybe someone from creators port it for GTR2.kotobuki09 escribió: 30 Mar 2022, 08:03I create this version but it's only for GTR3 and GTR3 Pro only. Not sure how to convert to GTR2 though
- Contactar:
Thank kotobuki09 for original ported and layout script in GTR3Pro
Please read carefully before download.- use images as far as can be used from image from original watchface
- alexstam78
Thank you asoo, amazing as always. Sorry but what's the difference between two versions?
- Contactar:
alexstam78 escribió: 30 Mar 2022, 10:57Thank you asoo, amazing as always. Sorry but what's the difference between two versions?
version 1. Power use circle progress with image .
version 2. Power use circle progress with line
- alexstam78
Yes and what is the difference? Because they seem same to me.asoo escribió: 30 Mar 2022, 12:06Spoiler
alexstam78 escribió: 30 Mar 2022, 10:57Thank you asoo, amazing as always. Sorry but what's the difference between two versions?Power circle barSpoiler
- Contactar:
Ver 1. formed by image picture
Ver 2. formed by calculate with linear calculations
You look at the picture to see the difference.
- Use images to process will have dimension shadows.
- Use linear calculations to process will be a monochromatic image
Hope you can already see the difference.
It is not different to work , just use different the method and element to show on displaying.
If you don't see the difference You can use any of them. it works the same
- alexstam78
Thank you very much asoo, this is what I wanted to know if it is any better than 2 and i see the second is more clear than other.asoo escribió: 30 Mar 2022, 13:48Spoiler
Ver 2. formed by calculate with linear calculationsYou look at the picture to see the difference.Spoiler
- alexstam78
Sorry, can you fix the distance fonts numbers little left because the last number touches the pin of the distance icon and makes it difficult to see well, in fact it is closer than in the preview. The powerline version with image. Thank you.
- Contactar:
I don't know how many pix that you told "little left" .
I don't have a GTR2 , this is one of the reasons I don't want to port a watch face that I don't have because I can't see the results displayed on the physical device.
If possible, you should find a solution yourself. But you'll always say you can't. So I probably won't be able to meet your requirements either for the reasons I mentioned above.
This is the final fix of this watch face and from now on if I port a watch face and the element watchface is slightly wrong. I ask not to fix Because I can't do it properly according to the real device. including being unable to comply with the request of the requester
So I write a notification message every time the job is done uploading
as follows:
If who want to modify or edit or change something please do it by yourself.
therefore learned to know
Last modify:
This tested on editor program , if you do not like it , I can not do it better than this.
viewtopic.php?p=12439#p12439
as follows:
Last modify:
- alexstam78
If you see kotobuki09 GTR3 Pro preview you see the difference, the distance numbers are little left than your version, it's not your fault, I have noticed that sometimes things are not as they seem in the preview but they are different in reality, so sorry for that and thank you. Fixed now.
- Contactar:
Of course I've seen that difference since I started the port.alexstam78 escribió: 27 Abr 2022, 07:51If you see kotobuki09 GTR3 Pro preview you see the difference, the distance numbers are little left than your version, it's not your fault, I have noticed that sometimes things are not as they seem in the preview but they are different in reality, so sorry for that and thank you. Fixed now.
That the layout after the port is not the same.
Caused by the original work, size 480x480, port to GTR2 with size
454x454 you must to reduce the image size. The down scaling process uses an approximate value of (0.946) so all resources are make down scaling . image size and layout may change. When bring to built a new layout, the spaces may change.
If you try it yourself, you'll understand the problem I'm talking about.
I think I'd to end this discussion on this topic, that all
Thank.
¿Quién está conectado?
