Please, convert theese watchfaces to [GTR 3]
fer_92
Post by fer_92 »
Hello everybody!
I just bought a GTR3 and I'm absolutely lost.
Could anybody convert/adapt from their respectives watches to the GTR3?
Most of them are from the GTR 47mm, but the first one is from the GTR2:
Buumcomic - Bubba1968 - GTR2
Batman anime - piantala - 47mm
Press Start To Play - cjcmuriel - 47mm
Star Wars - maikeandre - 47mm
Pika Walk - aim4menow - 47mm
Pokemon Pokeball Style - wing0826 - 47mm
Please, could anybody help me?
Thanks a lot!!!
Has thanked: 404 times
Been thanked: 2024 times
fer_92 wrote: 06 Mar 2022, 06:28
This watchface, I am interested in making GTR3 , other watchface please waiting for those who are interested to help you further.
Buum_FAOD_GTR3.zip
(248.41 KiB) Downloaded 66 times
fer_92
Post by fer_92 »
asoo wrote: 06 Mar 2022, 08:01
Buum_FAOD_GTR3.zip
Great! It's so cool!
But the AOD mode has a problem.
It shows the backgroud. I tried to remove the background image, but another problem appears.
The images of numbers and other items (date, weather, steps...) are black, so it can´t be seeing with the black background of the AOD. The only thing that shows good is the time. Enought, on the other hand.
This is the second time that you help me today! Tell me, how do you do this conversions so fast?
And how can I convert .bin from 47mm to .zip for GTR3? Maybe I could help others!
Thanks a lot, again!
fer_92 wrote: 06 Mar 2022, 08:51
Buum_FAOD_GTR3.zip
if you want to modify AOD in background black you must to create new image about you talk in white
In this case i will not do it's , I do only convert to GTR3 if you want to modify please do it by yourself
if you want to convert GTR47mm or GTR2 to GTR3 you must to unpack BIN and after unpack you can bring the image to make the GTR3 with the program editor , As far as I know, there is no shortcut for convert of this nature. If you do it often and have a good understanding of how to use the editor. You will be able to do it smoothly.
All Program editor about Amazfit GT you can find the forum is this link :
viewforum.php?f=29
fer_92
Post by fer_92 »
asoo wrote: 06 Mar 2022, 10:24
Buum_FAOD_GTR3.zip
viewforum.php?f=29
Great, thanks!
How can I unpack the .bin files? And, how I create a new base watchface to add the images from de bin? Should I work over a existent watchface and replace the images and positions?
And can I upload my modified .zip files to the app for share and get the watchfaces from the cloud?
fer_92 wrote: 10 Mar 2022, 07:53
Great, thanks!
- You can unpack BIN by use program edit that match the type of the Bin file.
In the program editor have function to Unpack , after you unpack you can found all picture for that watchface in the folder watchface at the path of program editor.
- Yes, you can share , if you want . ( recommend If possible, should tell the source of the watchface you bring to edited and share )
kotobuki09
Post by kotobuki09 »
What is the popular wf editor for GTR2?
I try to unpack from wf and turn it into GTR3 Pro
kotobuki09 wrote: 17 Mar 2022, 20:19
viewtopic.php?t=1888
kotobuki09
Thanks but it's not a unpack the wf that I want!!
