Jeweler tiger watchface for GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2 and if is possible add weather. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators and to community for hospitality.
Image.
Has thanked: 441 times
Been thanked: 2142 times
JTR_FAOD_GTR2_packed.bin
(687.78 KiB) Downloaded 83 times
- I will only convert from original , I will not accept any request to edit or modify or change something from this converted.
alexstam78
Amazing work, I like it very much, thank you, asoo, much appreciated. I test it and it's ok.
