Requesting port [GTR2]
sabahulghani
Post by sabahulghani »
https://amazfitwatchfaces.com/gtr/view/7621
can someone port this watchface for gtr2
It would be a great addition to the watch faces for gtr2
Has thanked: 404 times
Been thanked: 2022 times
Please select one model you want to port.
Because cannot do all versions
sabahulghani
Thanks Asoo, can you do that for gtr 2e
sabahulghani
If you meant by the color for the watch face yellow will do the trick Image
sabahulghani wrote: 08 Feb 2021, 13:46
X500Yellow.bin
(663.58 KiB) Downloaded 391 times
sabahulghani
Thanks Asoo really appreciate your time and effort
alik7676
Has thanked: 24 times
Post by alik7676 »
plz add full aod
alik7676 wrote: 11 Nov 2021, 17:30
plz add full aod
X500Yellow_FAOD_GTR2.bin
(636.67 KiB) Downloaded 147 times
- Full AOD.
alik7676
Post by alik7676 »
thank you very much
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Amazing work but the temperature wants a little more left because it falls on the perimeter of the circle.
alexstam78 wrote: 13 Nov 2021, 05:24
Fixed
viewtopic.php?p=11049#p11049
If the gap is not satisfied You can fix it yourself. by using the Editor program
viewtopic.php?f=29&t=1888
alexstam78
Thank you for the fix.
jorixine
Post by jorixine »
Is it possible to port this one (grey/grey version) to GTR3 ?
AOD == Only Time if it is possible.
THanks!
I think this topic is "Requesting port [GTR2]" if you would like to request to port to GTR3 I recommend you to open new topic , and attach the information you need such as images or links related to your request in the new topic to it.
