- Amministratore
Do all of the watch faces on here only suppor 24H time? [GTS]
I've tried several watch faces for my GTS and all of them only show 24H time format.
Is 12H time format not supported?
- cepdanie
- Has thanked: 5 times
- Been thanked: 6 times
- Contatta:
it is supported
try in my catalogues:
https://amazfitwatchfaces.com/search/gt ... rID/121057
like this one for an example:
https://amazfitwatchfaces.com/gts/view/5331
Your watch faces are very professional!cepdanie ha scritto: 07 dic 2021, 17:49Spoiler
it is supported
I noticed that the 12H digital clocks have a "leading zero (0)" - is that required?
What software did you use to create your faces?
- cepdanie
- Contatta:
1. Corel Draw for shaping
2. AI for bridging and making elements
3. Photoshop CC for assembling, scaling and finishing
4. viewtopic.php?t=1076 for creating a watch face.
Thank you so much for sharing!cepdanie ha scritto: 08 dic 2021, 14:11Thanks
About the 12H time mode, why does it display like this?
04:24
Is it possible to display like this (without the "leading zero")?
4:24
I would also very much like the watch faces 12 hour with no leading zero. Thank you
