G281 and G280 [GTR2] asoo
- alexstam78
- Has thanked: 173 times
Hello to community, can anyone from creators modified this lovely watchface from asoo to remove the distance from G281 and pulse from G280 and in its place to put there the time of sunrise and sunset, I will appreciate it very much and thank you.
https://amazfitwatchfaces.com/gtr/view/19511
https://amazfitwatchfaces.com/gtr/view/19219
- Has thanked: 441 times
- alexstam78
It's my fault I did not say it correctly, can you remove completely sunset time and sunrise time from the point you had them and the time of sunset and sunrise shows to the point where you put them now but not to be at the same time as now, thank you very much.
- alexstam78
I mean like this picture. remove completely the time in the little numbers and make it like original.
When it is sunrise the time comes out with the sunrise icon as in the original and when it is sunset the time comes out with the sunset icon. Thank you again very much.
I am not sure it work or not but the last time I use sunrise/sunset ( image progress ) it not work , it show not correct on real device so this watchface i will not test you must test by yourself , if not work , I just can't fix the problem.alexstam78 wrote: 24 Nov 2021, 10:14I mean like this picture. remove completely the time in the little numbers and make it like original.
- alexstam78
Thank you very much, friend, I've tried both at sunrise and sunset, and they all work as they should, only one thing I found wrong, you must reverse the icon beside the time of sunset and sunrise. I mean here now at Greece the sunrise is at 7:16 and the Watchaface and the pointer shows the sunrise and the time is correctly 7:16 but the icon beside the sunrise time is the sunset icon.
That's the problem I mentioned. ( although preview image show normal but on real device is not ) I don't know why it doesn't display properly either.alexstam78 wrote: 24 Nov 2021, 11:47Thank you very much, friend, I've tried both at sunrise and sunset, and they all work as they should, only one thing I found wrong, you must reverse the icon beside the time of sunset and sunrise. I mean here now at Greece the sunrise is at 7:16 and the Watchaface and the pointer shows the sunrise and the time is correctly 7:16 but the icon beside the sunrise time is the sunset icon.
I can't fix this problem. So I avoid using sunrise sunset's image progress.
If I'm not mistaken , switching images, does not fix this issue.
If you want to test it, I recommend you to unpack "BIN" file and try swapping the images. By changing the image number and repacking to test by yourself.
You can use "AmazFit WatchFace editor 2 for Windows program" to do this.
viewtopic.php?p=8392#p8392
- alexstam78
Ok friend, thank you for info and thank you for the port. doesn't matter.
- alexstam78
Hello and sorry again, friend, can you at least take off the icon of sunset and sunrise behind the time of sunset and sunrise and leave it only with time. The problem is the icon, the sunset and sunrise time works fine. Thank you for all you done for me.
alexstam78 wrote: 26 Nov 2021, 14:56Hello and sorry again, friend, can you at least take off the icon of sunset and sunrise behind the time of sunset and sunrise and leave it only with time. The problem is the icon, the sunset and sunrise time works fine. Thank you for all you done for me.
