Johnson070
Been thanked: 13 times
Post by Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
Dr.Uberveguad
Post by Dr.Uberveguad »
Can't downloaod this because windows said it has a virus.
Goublin
Post by Goublin »
Thank you very much for the program.
ssyar
Post by ssyar »
pepe pepon wrote: 15 May 2021, 12:50
I am getting a "Trojan:Win32/Zpevdo.B" warning from Windows Security
i am too having same issue on Win 10
jasonberry8017.369
Post by jasonberry8017.369 »
Hi, I wanted to thank you for your program, it was very useful to me. I also wanted to ask you if you could add more features.
E.g: In my watchface there is an animation, I would like the animation to change at a specific time or a specific day, etc.
Thanks again for everything .
Nickrosfire
Post by Nickrosfire »
a little problem, i save my file as .bin but nothing appears... is that a bug? or i am doing something wrong?¡
luridfox
Post by luridfox »
I seem to be having some issues. I am trying to do a couple of basic edits on an existing one. I made the changes and saved it as a .bin file. The file is not where it says it is, nor can I find it elsewhere. I just get a log file.
How can I do this correctly?
SanKarstiko
Post by SanKarstiko »
what is the address to paste the .bin file in MIUI?
miklav
Post by miklav »
I am also getting a warning about trojan from Windows defender when I download the package (as some other users reported above). So to be on the safe side I use it in a virtual machine (had to add an exception in Windows Defender to be able to download it).
Bin file is saved in the same folder with all the project png and json files.
pipouses
Post by pipouses »
hello how do I get the time and date on top of my animation? when I but add an animation everything goes below
sachok
Post by sachok »
Hello everyone! I create a watch face for myself with a date and choose to show the date in a single value, but on mi band 6 the date is always displayed in a two-digit form. Is this a bug or is there some kind of trick?
pipouses
Post by pipouses »
I think before you are an answer you will have found all alone for a while I asked a question 0 we answered ...
I think it's a half-dead application since it doesn't respond even after 17 days
Tankudoraiba
Post by Tankudoraiba »
I made several other watch faces, but none of them work properly on Mi Band 6 NFC. Animations are bugged and date doesn't show up. What I don't understand, watch faces from the web work.
zengqin0825
Post by zengqin0825 »
不错
Rosta949
Post by Rosta949 »
PsychoMatt wrote: 13 Jul 2021, 12:06
Hi
pls help me. i cant save bin file
Save to mi 5 !
Aramon
Post by Aramon »
Does anyone know the reason why the weather is not displayed if I add UV Index or Wind Speed or Night Temperature to the dial?
dams88
Post by dams88 »
Aramon wrote: 31 Oct 2021, 13:56
Hello, if you find the answer, I am very interested. Thanks Dams
Fany_VanDaal
Post by Fany_VanDaal »
Hi, you're probably using an antivirus. Turn it off. Also go through the quarantine in the antivirus, some script will be stored there, so enable it.
Hi
Rosta949
Post by Rosta949 »
If it is not possible to save the .bin file and the Gif animation to MB6:
Clear MiBandWatchFaces.exe in the antivirus quarantine
run MiBandWatchFaces.exe as an administrator
Rosta949
Post by Rosta949 »
Nickrosfire wrote: 24 Aug 2021, 19:59
Rosta949
Post by Rosta949 »
Fany_VanDaal wrote: 03 Nov 2021, 07:56
Hi
run MiBandWatchFaces.exe as an administrator and put the cover in antivirus
ahmadjie80
Post by ahmadjie80 »
after add PAI....weather,date,week of day not working.....can anyone help?..thanks
Rosta949
Post by Rosta949 »
dams88
Post by dams88 »
ahmadjie80 wrote: 09 Nov 2021, 09:23
My issue was fixed by adding a decimal point.
ahmadjie80
i will try...thanks
Xyxaba1
Post by Xyxaba1 »
Hi I'm having a problem editing an existing watch face, i wanted to switch places between hours and minutes so i changed the image selection and positionaccording to it but after changing that the other elements such as date day etc get behind the numbers whereas befoee editing they were in front of them..
