Tool to scan for (partially) transparent images
l1lN1ckl1l
Post by l1lN1ckl1l »
Transparency and partial transparency can bump up the file size of your images and also the file size of your watchface bin.
This tool scans all the images in your watchface's folder and spits out file called results.txt containing detailed information on what images contain transparent or partially transparent pixels and how many of them.
To use, simply copy the program over to your watchface's folder and run it.
Ashampoo_Snap_Sunday, October 13, 2019_17h18m39s_001_.png (14.13 KiB) Viewed 6767 times
Download:
Image Scan.zip
64 bit only
(8.29 MiB) Downloaded 738 times
This little program is the first of [mention]Urimu[/mention]s and my tools designed to reduce the filesize of your watchface and optimise it. More will be coming soon
Nick
