This smartwatch features up to 45 days of battery life, GPS, heart rate, multisport tracking, and notifications at 1 oz weight
Device Features
Screen: Reflective, color, 2.5D, Gorilla Glass 3 with oleophobic coating.
Screen Size: 1.28 inches.
The sizes of the case:
B x W x T (in mm)
41.5 x 34.7 x 9.6
The length of the strap: 11 + 8.5 cm.
Strap width: 20 mm.
Weight: 32 g (including the strap 14 grams).
Battery: 190-200 mAh (lithium polymer).
Charging time: 2.5 hours.
GPS: + GLONASS (dual positioning mode).
Bluetooth 4 BLE
Autonomy: 45 days (1 half-hour run per week, 10% backlight brightness, 100 alerts per day, no firmware updates).
In standby mode: 4 months (time display, step counting, sleep monitoring).
Menu language: Chinese.
The data sent to the phone will be displayed on the phone in the phone language. Clock notifications will be displayed and displayed in the phone's language.
To work, the phone must have an application called amazfit or Mi Fit (3.x.x for android (4.4+) and iOS (8.0+)).
The watches are dust and waterproof according to IP68 standard and can withstand submersion up to 1.5 m depth in ordinary fresh water at normal temperature up to 30 min, but not for bath (high temperature) and not for swimming.
Firmware proprietary (not android wear).
The global version, with the interface languages different from Chinese and English, does not exist!<br/>
Differences between the English and Chinese versions of the watch in a piece of paper with the English text inside the box, several English words on the box, the CE sign on the box and on the bottom of the clock (next to the heart rate sensor). They also have a different HW ID, which can be seen in Gadgetbridge. The Chinese HW V0.11.1.4, the international (English) HW V0.11.2.4.
FAQ
- Using the paid version of Notify & Fitness for Amazfit (having adjusted the reaction to the button presses) or Mi Band 2 Music Control.
"How are these hours of vibration?"
- The vibration is good, at the level of Mi Band 1 (not weaker). The clock, as well as the bands, has a small spread in the strength of the vibration.
- Does a PC watch if it connects the charging dock to the computer?
- No. The clock shows 2 contacts, only for charging.
- What other programs can work with the clock?
- Notify & Fitness for Amazfit
- Where or from what service do the clocks take the weather?
- The weather is taken from Mi Fit, and he receives from AccuWeather.
- How to transfer statistics?
- Using mi fit exporter.
- How to install the firmware using iPhone?
- No way. So far only for the android there are programs with which to put the firmware.
- How long can I view the message?
- On 2 hours screen (scrolls with a swap), about 230 characters. If there is more, the rest will be circumcised (will not seem).
- On the watch, in the place where the strap is fastened, there is a hole. What is it for?
- It is necessary for the work of the barometer.
- When several messages arrive from the same application, the messages are grouped into one "messages in x chats".
- The essence of the problem. Alert Bridge for Amazfit Bip helps to solve this problem.
- Does the magnetic clasp affect the compass?
- Yes, it does.
- How on this watch to measure (see) the pressure and height?
- Go into the compass and left. Not available on all firmware.
