WatchFaces - need help
Bloccato
MadMaxPain
Messaggio da MadMaxPain »
Hallo all,
i tried to use some of your WatchFaces and copied them (by your howto) in the folder WatchFace.
But i cant use them. Also i cant see them.
Was it wrong?
Where can i see the new watchfaces? In the Amazfit-App or only in the Watch?
Please help.
Best regards
Max
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Messaggio da osmat »
If you copied to the correct folder then watch faces will be available both in the application and in watch. If your iPhone previews will not be displayed in the application
MadMaxPain
Hallo Osmat,
thanks for your answer.
But i copied the downloaded .wfz-File in the Folder: "WatchFace" (see the screenshot) but they i cant find them.
Not in the Amazfit App an not on the Watch.
What is wrong? What do i wrong?
Dates from the Watch:
Modell: A1619
Rom-Version: 2.3.10.5
Hope you can help me.
greetz Max
Bloccato
Torna a “Closed topics”
