I have been using a stratos since December 2018. Love it, great watch!!!
The other day I took it off the charger and noticed the bluetooth connection was not functioning. I checked my phone and BT indeed was functioning with my motorola and Fossil smart watches just fine. I also have some BT headphones that work fine. So I turned my phones bluetooth radio off and then back on, it still didn't connect to the watch.
I proceeded to clear my phones cache and reboot the phone, that didn't work.
I also rebooted the Stratos that did not work either.
I let it sit for a day thinking it might fix itself, but that didn't work.
So I did a factory reset on the Stratos. I uninstalled Amazfit watch app from my phone. Re-downloaded Amazfit watch app onto my phone, and tried re-install procedure...
I Log into the app with my password and proceed to pair the watch with the app. I get to the QR scan code on the watch, scan that with the app. The installation gets stuck there. It cycles/spins for ~20 seconds on the watch and the watch reverts back to the scan code screen. The installation can't seem to move past the scan code screen.
I can long press the power button and reboot the watch, but it still gets stuck at the scan code screen. At that point when I try and re scan with the app I get a message that the code is already scanned.
SO it seems like the watch is stuck in a software loop right after the QR scan code screen.
I can still access the watch file structure with my windows PC USB port. Is there some way to re-image the watch through my PC?... or flash a fresh firmware onto it?
thanks!!
Help with Stratos setup.
kramer5150
kramer5150
Hi all... I got my stratos to connect and work again. I had to re-register the app under a new email address though. Not a huge deal.
