Request IWC George Russel Watchface
deepblue2000
Post by deepblue2000 »
hi,
It would be great if someone could make this WF for GTR4
https://www.iwc.com/eu-de/specials/geor ... re-in-time
many thx in advance
MarioLie
Has thanked: 57 times
Been thanked: 37 times
Post by MarioLie »
deepblue2000 wrote: 19 Mar 2026, 14:34
hi,
many thx in advance
This is a nice watch design and if you're interested in it, I'll create it for you, but I won't include their brand name there due to copyright protection. If that's okay with you, I can put your nickname there instead of the label.
This is how the AOD version could look like
Preview AOD
deepblue2000
hi,
I would like to have it with IWC, not with my Nickname.
here at amazfit there are a lot of iwc watchfaces, do you think it will be a problem ?
would be nice if you can do it.
thx
MarioLie
Post by MarioLie »
deepblue2000 wrote: 20 Mar 2026, 10:35
hi,
thx
There are also a lot of plagiarists here and I don't make plagiarism I create identical works without marks which means the work is authentic. If you don't want to do it without IWC then I won't do it.
Preview
Rather tell us what information you want in the circles and whether you want numbers in the circles or just indicators.
deepblue2000
I think Its enough without the circles.
just default like the first preview
so your 2nd preview without the circles would be enough.
(but with weekdays/days on the right)
but if you have already done the circile, then: battery, heartrate and steps (as indicator)
edit: ich seh gerade du bist ja aus Berlin, dann macht das Englisch schreiben weniger Sinn ;)
so wie ich das gesehen habe, ist die default George Russel ohne die drei "Kreise" die mit den drei
"kreisen" ist die Piloten Version. ich weiss nicht ob es technisch möglich ist , das man zwischen den designs wechseln kann. dann wären beide in einem natürlich top, aber ist ja eine menge mehr arbeit.
thx !
MarioLie
Post by MarioLie »
deepblue2000 wrote: 20 Mar 2026, 13:04
thx !
Ihr Aussehen finden Sie zum Download unter: https://amazfitwatchfaces.com/gtr/view/44670
deepblue2000
Dank dir, super Arbeit !
