Convert .FACE project to .BIN for publishing.
MKC
Post by MKC »
Thanks to EasyFace I was able to create my first watchFace for my band 8.
I am able to generate a project (almost, more or less) in .face format, but I don't know how to compile it into .bin so I can publish it.
Has thanked: 1181 times
Been thanked: 281 times
MKC wrote: 16 Mar 2025, 09:29
It’s possible that the .face file you generated is essentially the same as the .bin file required for publishing. If you can share a sample .face file with us, we can take a closer look and verify its compatibility.
MKC
Post by MKC »
I just created a watchFace with MiCreator, in .face format and rename to .bin
ChibiClock.zip
File format .face
(366.11 KiB) Downloaded 148 times
It works, but...
Insert an animation with the code "anim_[00@100]" with the header ImageList,
and the result is that it looks good in MiCreator. But I'm attaching a video of what is shown.
error_animation.zip
video error animation
(2.34 MiB) Downloaded 122 times
Where can I learn about image formats and their resolution?
MKC wrote: 16 Mar 2025, 22:58
I just created a watchFace with MiCreator, in .face format and rename to .bin ChibiClock.zip
It works, but...
error_animation.zip
The .face and .bin files are essentially the same format, so renaming .face to .bin works without issues (publishing).
Regarding image formats and resolution for animations, we don’t have precise details on supported specifications. The official MiCreator documentation or their community forums would be the best resource to clarify image requirements.
You might want to experiment with simpler or smaller-resolution images to identify what’s causing the animation issue.
