Edit watchface inside AmazFaces app permissions set on website?
Questions about the main site. Authorship questions.
Moderator: Internal error
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Hey guys, in new update we have option to edit watchface (yeah in beta...) but not every author want option to edit he's work by others users... So maybe We (authors) should have option on website to enable / disable this option inside our watchfaces?
Has thanked: 1149 times
Been thanked: 276 times
TRK88PL wrote: 03 Feb 2024, 11:48
Thank you for reaching out and sharing your concerns regarding the new feature in our beta update that allows users to edit watch faces. We understand the importance of respecting authors' rights and intentions for their work.
To clarify, the editing option is designed to offer limited adjustments, enabling users to personalize visual aspects of the watch faces to better suit their preferences. We assure you that this feature does not allow for extensive modifications.
We are also planning to implement a system where any edited watch faces can only be installed directly on the user's device and will not be redistributable. This ensures that your original work remains protected and attributed correctly.
We value your feedback and are considering adding an option for authors like yourself to enable/disable this editing feature for each of your watch faces on our website. Your input is vital for us to create a platform that respects creators' rights while offering flexibility to users.
Thank you for your understanding and support as we continue to improve our service.
Return to “amazfitwatchfaces.com site/catalog”
