Amazfit verge is an outstanding smartwatch that has got a spectacular design that makes it a great choice for a whole lot of people. It got lunched officially in Amazon India few days ago and a whole lot of people probably are yet to come to terms which one is better between Amazfit verge and Amazfit stratos.
Amazfit Verge vs Stratos Design Compared
To compare these two, we should perhaps start from the design and outward appearance. The difference is very clear, while Amazfit verge has a sporty design, the Stratos has a classic design. Based on this observation it would be safe to say that Amazfit Verge is a better choice you should wear while working out. Don’t get me wrong, am not saying that you can’t wear the Stratos to your sporting events. What we are looking at here is which one is better, after all these two are great choices to wear for any occasion.
Let’s compare the display, Amazfit verge has AMOLED while Stratos has transflective LCD. Obviously AMOLED is the most interactive and lively, only second is OLED, but the LCD is brighter and consumes less power compared to AMOLED. So Stratos is more visible under sunlight compared to Amazfit verge.
In addition, Amazfit verge weighs less, this further confirms the claim that it is actually the better choice to buy if you want something to put on as a casual wear or better still the perfect fit for sport events.
Verdict: Overall, both smartwatch look great but they part way in the appearance with Amazfit verge having a sporty design while the Stratos is a Classic fit for your official occasions.
Amazfit Verge vs Stratos Waterpoof Levels Compared
We don’t need to say much here because the difference is very clear, while Amazfit Verge is rated IP68, Amazfit Stratos is rated 5ATM. This off course means that with the Stratos you can go deep up to 50 meters which it the better choice for tracking your swimming activities in the ocean or pro. On the hand, Amazfit verge is only waterproof up to 1.5 meters under water which means you can wear it under rain or to your shower, but I don’t recommend it for tracking your swimming activities.
Verdict: Talk about tracking your activities in water, then you should go for the Stratos.
Amazfit Verge vs Stratos Battery Life Compared
We all know how important battery life is when it comes to choosing a smartwatch and in this regard both of these two have long battery life. Amazfit smartwatches have done so well as far as battery life is concerned. We had expected the battery life of Amazfit verge to be lower than the Stratos, but that’s not the case.
Amazfit verge has a slight longer battery life, on regular usage we are looking at least 4 days or more while on the Stratos it’s about 2 days or more. However, you should keep in mind that battery life varies among different users, but make no mistake any of these two will let go over a day on a single charge.
Verdict: Amazfit verge has a slightly longer battery life than Amazfit Stratos which again makes it the better choice for tracking your fitness activities.
Amazfit Verge vs Stratos Price Compared
Amazfit verge cost less than the Stratos, you can buy an Amazfit stratos for $155 while the Stratos will cost you more. It cost about $200 or maybe more depending on the merchant. Read further to know which of these two give the better value for your money.
Amazfit Verge vs Stratos - Which is More Complete?
We expect Amazfit verge to have updated processor and chips compared to the Stratos. This actually will go a long way to improve user’s experience. With that said, we noticed a microphone on Amazfit verge which means you can answer calls directly from the watch. You can’t do that with the Stratos.
Another very important feature found on Amazfit verge is an NFC chip which supports Alipay a mobile payment system that lets make payments on the go.
With all the observations we have made, it is a matter of what do you want from a smartwatch. You probably want a smartwatch that can do as many possible things as possible that’s if design and appearance is not your main concern. With that said, it is obvious, Amazfit verge has more features. You get NFC and a built microphone which makes life easier.
Conclusion
So in summary, Amazfit verge is a fantastic choice, the price is just within mid-range and the design means you might actually be getting more value for your money. You can wear it as a casual wear and who says you can’t wear it for official duties. I would go for Amazfit Verge even though the Stratos is a very great choice.
Amazfit Verge vs Stratos - which one is bettert?
smartwatchse
Join us at Smartwatch Series for full specifications of the latest smartwatches.
I agree....unless you tend to go swimming!
Amoled screen I feel much better. Even outside my Pace screen hard to see unless direct sunlight on it. At angle very had to see. I find Verge better.
