- Online in Mi Fit app where I see 15, where 2 are duplicates so only 14 unique
- Local in Mi Fit app which used to contain original watch face and now contains faces I select from Online faces in Mi Fit
- Settings on watch which contains 10 faces (plus the one currently displayed), one of which is the original watch face and none of which are in the 2 lists above - I do not need a bluetooth connection to my phone to select these faces so these seem to be permanently stored on the watch
- Is there an official way (using Xiaomi tools) or unofficial way to change the faces stored on my watch (list 3) - I thought I should be at least be able to change, from my watch, to the local faces (list 2)
- Is there an official way to change the limited 14 faces in online list in Mi Fit app (list 1) or can this only be changed by third party apps or by copying files to /Android/data/com.xiaomi.hm.health/files/watch_skin which works, but does not update image on online list and it stops selecting face in online being copied to local list (list 3)
Mike
