Exactly what it says on the tin. I've got Spotify paired and the clicks set up, but it does nothing on the watch. Additionally, the "Paired Device" menu is stuck on "Connecting to your wristband..." -- I was able to install a custom watch face via AmazTools though, so it must be connecting on some level.
Any advice on how to fix? Thanks.
AmazTools Music Controller Not Working?
usman_patel87
Try the app name "Amazfit BIP Assistant from Google Play Store if using Android phone.
