Question about aod in T-Rex Ultra
EmaPolice
Post by EmaPolice »
Hi, I noticed the whatchface position changes in full aod mode.
Specifically, compared to normal mode, when switching to aod mode, the whatchface is moved a few millimeters. This, in some whatchface, represents a problem because it "cuts" some elements.
Is there any way to avoid this?
Thank you
Lozzy44
Post by Lozzy44 »
When it swaps to Aod mode the position changes every so often so to prevent screen burn I believe
EmaPolice
Post by EmaPolice »
Yes I had imagined, however this would require a solution for those whatcfaces that have symbols, icons and numbers near the "crown" of the watch. Otherwise, when aod takes over, some symbols are cut off.
Again, to a careful observer, the dial appears "shifted".
