In a few days, I will receive the Mi Band 8 and I have a question:
Can applications be installed on the Mi Smart Band 8?
From what I ask, it doesn't have Zepp Os, so I don't know if applications can be installed or not on 8 like 7.
Thanks for this mod app bro, it's works perfect, but i found one AOD in this app can't download, can't you check itarizon wrote: 23 Aug 2023, 02:36You can add several games that are not on the official Mi Fitness and 1 calculator application.
first uninstall official Mi Fitness, then install with the link below
here's the link :
MiFitness_3.18.0i_m0tral_v121.apk
https://drive.google.com/file/d/1_oLQ0a ... sp=sharing
