Amazfit Band 7 Watchfaces
Hello!
I'm looking for some Amazfit Band 7 (do not mistake it for the Xiaomi Mi Band 7) custom watchfaces but i can't find it anywhere.
Are you guys planning on adding Amazfit Band 7 support on your website/app?
Also, i've noticed that the Honor Band 6 has the same resolution as the Amazfit Band 7, maybe you can merge the 2 bands as a single category?
- GIK-Team
- root
- Has thanked: 1181 times
- Been thanked: 281 times
Hello! We plan to add this model to the catalog as an addition to Mi band 7. This will happen in the near future 1 - 3 days.f4bulous wrote: 15 Nov 2022, 04:08Hello!
- GIK-Team
- root
f4bulous, we have added a new section. We are waiting for new dials to be added to it.
Nice! I'll start uploading some watchfaces soon, tho i find it weird to put the Amazfit Band 7 catalog as an addition to Mi band 7, since they have different resolutions (Mi Band 7 is 122px taller).GIK-Team wrote: 15 Nov 2022, 16:38@f4bulous, we have added a new section. We are waiting for new dials to be added to it.
Thanks for the reply!
- GIK-Team
- root
We know, but we can’t separate them yet, because we don’t really understand how many dials will be added.f4bulous wrote: 15 Nov 2022, 16:51Nice! I'll start uploading some watchfaces soon, tho i find it weird to put the Amazfit Band 7 catalog as an addition to Mi band 7, since they have different resolutions (Mi Band 7 is 122px taller).
- GIK-Team
- root
f4bulous
We have separated the Amazfit Band section. Your watch faces have been moved to a new section of the site.
Hi!
I am happy to see the new section, but there are no specific instructions for installing watchfaces on the amazfit band 7. On pc the files are .zip, not .bin so the susbstitution trick is not the way to go (I guess?).
The app does not allow installation in android 12, it stops right after you tap on "install", the bar never fills. I also tried the basic bt/permissions/app reset, no luck
- GIK-Team
- root
Hello! What version of the app?trogoz wrote: 21 Nov 2022, 11:17Hi!
This is 3.9.262 , i tried both on a Xiaomi mi 11 lite 5G, and an Oppo find x3 pro, both android 12GIK-Team wrote: 21 Nov 2022, 12:15Hello! What version of the app?trogoz wrote: 21 Nov 2022, 11:17Hi!
- GIK-Team
- root
Update to latest 3.9.268trogoz wrote: 22 Nov 2022, 08:51This is 3.9.262 , i tried both on a Xiaomi mi 11 lite 5G, and an Oppo find x3 pro, both android 12
Omfg thanks man it worked!
I had to re-synchronize with Zepp app and now the download process proceeded. I installed the watchface now, thanks!
I am really happy with this, now I have to learn to develop my own faces and post them on the website!
THANKS!
THANKS!
