AmazfitBipTools Not working for me
shrewdroid
Messaggio da shrewdroid »
hi friends,
I am want to create a custom watch face, but when I try to extract any bin file downloaded from the gallery I keep getting the following error:
Codice: Seleziona tutto
Debug|Opening watch face 'C:\temp\amzfit\comic-271988-0d4cb4da53.bin'
Debug|Reading parameters...
Trace|Reading header...
Trace|Header was read:
Trace|Signature: UIHH?, Unknown: 4294967040, ParametersSize: 4294967295, IsValid: False
Debug|Parsing parameters...
Fatal|System.NullReferenceException: Object reference not set to an instance of an object.
   at WatchFace.Parser.Utils.ParametersConverter.Parse[T](List`1 descriptor, String path)
   at WatchFace.Program.ParseResources(Reader reader)
I am using the AmazfitBipTools-1.0.3.1.7z tool for extraction.
Can anyone tell me what is the issue?
Thanks,
Shrewdroid
oblus
Messaggio da oblus »
Did You manage with UIHH bin file? Im tryin to extract it without luck.
oblus
OK Ive got it ;]
Torna a “Watchfaces tools (discussion)”
