Guide to create watch faces for Bip-U, GTS, GTR...
ferno
Post by ferno »
I have created a guide for CREATING and INSTALLING watch faces for Bip-U, since I did not find anything published for this Amazfit model:
https://gist.github.com/fernospam/b0339 ... 4c94c511e6
also in spanish:
https://gist.github.com/fernospam/b0339 ... t-bip-u-md
The guide is also usefull for GTR and GTS.
I would like to thank user dAnnRioja for his huge help on preparing this guide.
I hope it is usefull for the community.
Sevens7
Post by Sevens7 »
Hi.
When i export the dial with https://watchface.huami.com/designer i got a .zap file.
I unpacked it with 7z and still there is no .bin data.
What i got is a asset directory, a watchface directory, and 2 index files.
Now the question is...how do i manage to make .bin files of the exported data?
or, what should i do with the exported files at all?
Forgot to tell that i have a BIP U PRo ;)
Omegaz
Post by Omegaz »
I'm facing the same issue for a bip u, received a .zap file and sending the QR is not working.
javi242
Post by javi242 »
In my case I get the .zab from the web and unzip it with  "The Unarchiver" (on Mac) and I get a .json and a .zip, and then I unzip this .zip and I get a .bin, but it doesn't work. When trying to install it starts and at the middle of the progress bar more or less it fails. Anyone was able to make this work? Thanks.
f4bulous
Post by f4bulous »
i also have the same issue, just exported the watchface and got a zab file
maybe we just rename it into a bin file?
Users browsing this forum: allsopsmr, Egalos and 1 guest
