need App update to latest Version
Mirbo
Post by Mirbo »
Hi, since a few days I have the problem that I can no longer install faces. The watch (MiBand 6) tells me to update the app to the latest version. But everything is up to date for me. Does anyone else have this problem?
THX
Stas
Been thanked: 34 times
Post by Stas »
Hi, we know about the problem and will try to solve it as soon as possible.
Mirbo wrote: 11 Aug 2021, 08:03
THX
Mirbo
Post by Mirbo »
great thank you! I thought it was up to me.
yutien
Post by yutien »
Me too and thank you!
Droid300
Post by Droid300 »
any fix to upgrading watchfaces to miband 6 after their firmware update? I can't install new faces now..
Mirbo
Post by Mirbo »
Hi, do you have any idea when the problem will be fixed?
Stas
Post by Stas »
Update the beta version, while the download on mi band 6 goes through MiFit/Zepp, on android 11 and above, you need to manually specify the path of the replacement file, for other versions, download automatically to the local folder MiFit /Zepp
Droid300 wrote: 18 Aug 2021, 13:04
Mirbo
Post by Mirbo »
How do I update the beta version? I have an iPhone for the transfer. I created a MiFit/Zepp folder and added a watchface to it. Nothing has changed. After about 1%, I get an error message that I have to update the app.
Mirbo
Post by Mirbo »
Hi, now i use the freemyband manual with an Android smartphone. It works and now i have the code. But if i now enter the code on my iPhone in the Amaztools app, then i get the message „Authetification error“. The MAC adress from the MiBand 6 and the code are identical.
does anyone else have the problem or a solution?
Thx
Stas
Post by Stas »
Contact support for these apps
Mirbo wrote: 10 Sep 2021, 17:07
Hi, now i use the freemyband manual with an Android smartphone. It works and now i have the code. But of I now enter the code on my iPhone in the Amaztools app, Thema i gest the message „Authetification error“. The MAC adress from the MiBand 6 and the code are identical.
Thx
