Page 1 of 1
Watch Faces with 12H, Miles, mm/dd, and Fahrenheit?
Posted: 30 Oct 2018, 23:31
by jtice
I am looking for some good digital watch faces that have 12H time, Miles (if distance is part of it) and fahrenheit for the weather.
and a mm/dd date format.
Re: Watch Faces with 12H, Miles, mm/dd, and Fahrenheit?
Posted: 08 Nov 2018, 16:29
by stupdude2
Shameless Plug - https://amazfitwatchfaces.com/bip/view/?id=14171
12H, Km (watchfaces can't display miles) and F weather. Date is spelled out including week day.
Posted: 09 Nov 2018, 16:44
by kimmh95
You can find many watchfaces if you search with the "mile" keyword.
I have also made a watchface with 12H, mile and ℉ at someone's request: https://amazfitwatchfaces.com/bip/view/?id=15441
But as stupdude2 pointed out, it looks like that watchface displays the distance in kilometers only.
I have not tested before whether the distance is displayed in miles correctly, since I do not use imperial units...
Posted: 24 Nov 2018, 03:10
by cloud12077
Just got my Bip today and having a blast with it. I found a Watchface that I really like, but I can't figure out how to change temperature from C to F and distance from Km to Mi.
I followed a youtube video that showed how to unpack the .bin file and I have everything in the editor, but nothing in the json seems to show switching between imperial and metric.
Any thoughts on how I can do this?
Posted: 24 Nov 2018, 10:42
by TXK
cloud12077 wrote: 24 Nov 2018, 03:10
You can set it in APP.
And the weather forecast is also switched in APP.
Posted: 24 Nov 2018, 11:14
by cloud12077
I have it set in the app, but it still shows up on my watch as C and Km rather than F and Mi.
Posted: 24 Nov 2018, 11:27
by cloud12077
Just noticed the temperature is correct (must be an image with the C I'll have to change), only the distance is different than what the app says.
Posted: 24 Nov 2018, 12:42
by TXK
cloud12077 wrote: 24 Nov 2018, 11:14
emmmm~
This "C" "km" is a picture, so only by unraveling this dial file and modifying the dial can the unit of measurement be displayed correctly.
Another way:
Look for a dial with "F". For example:
Https://amazfitwatchfaces.com/bip/view/?Id=12663
or
Look for a dial without "F" \ "C" . For example:
https://amazfitwatchfaces.com/bip/view/?id=13716
Posted: 24 Nov 2018, 14:04
by cloud12077
Thank you. Got it figured out. I was able to modify the distance (since I didn't care about that) and found the image I needed to edit to F.
Posted: 20 Dec 2018, 02:58
by ph34rful
cloud12077 wrote: 24 Nov 2018, 14:04
Sent you a PM
Posted: 29 Dec 2018, 02:25
by mbrown3
I created (edited) a watchface that also shows up as C rather than F, but it is NOT part of the image. I used the WF Editor by ilgruppotester. The watch is set to display Fahrenheit but it still shows the little C. When I toggle off the temperature display, the C disappears. When I re-enable it, the C comes back with the number, though the temperature is actually accurate (when I switch to show C in the watch settings, the numerical value changes. When I change it to F, it changes to the correct value, but still shows C). Anyone have any ideas?
Posted: 31 Dec 2018, 22:40
by rob22
that new watch face looks good. did you submit it? I was looking for one like that. thanks
Posted: 01 Jan 2019, 03:04
by SharkEmperor
Nice Work! Which watch face did you start with? I like the look of it.
Posted: 02 Jan 2019, 17:20
by cloud12077
Search for Mike76, he made the original. Here is my dropbox link to my modified verison.
https://www.dropbox.com/s/fhotgo7cays7d ... e.bin?dl=0
Posted: 03 Jan 2019, 03:02
by cloud12077
I modified and updated my watch face, which has been uploaded and found here:
https://amazfitwatchfaces.com/bip/view/?id=18507
Posted: 15 Jan 2019, 22:06
by SIR
Here you can find mm/dd, Fahrenheit and true 12h display (12:00 instead of 00:00):
https://amazfitwatchfaces.com/bip/view/?id=12663
Please download EN-watchfaces.zip and you will find thousands of variations. Read the discription carefully how to download and feel free to ask me if there are questions.
Regards
