Hello, my name is Pawel and here's sneak peak of my BrodatyWatchface that I made and worked on since few days. I would like to mark Vladimir here aka Johnson070 for making his cool program that I used to make this watchface
GIF below.
ENGLISH VERSION: https://amazfitwatchfaces.com/mi-band-6/view/379
POLISH VERSION: https://amazfitwatchfaces.com/mi-band-6/view/378
(if you would like to see your language, like German, French I need three things: shortcut for "ON", shortcuts for month names and days)
Four progress bars
I really liked a certain watchface from MiBand 4 that wasn't rolled out on versions 5 and 6. So I decided to make my own. There are four progress bars - blue (steps), yellow (calories), red (heart rate / pulse), green (power / battery level). Each of them have progress, so you can see if your pulse is high, battery is low etc.
Also there are numbers for every bar - so you can see pulse like 90, or battery level like 30%.
Bluetooth Icon
It's at the left-top side of the screen. If your MiBand 6 is connected to phones Bluetooth, it will be highlighted and blue bar at the left will appear. It's easy to see if you lost connection or not
Lock icon
Some people like to lock their screen some not. So you can see if it's locked by green bar at the left and highlighted lock icon. If lock is off or you will unlock your screen this green bar and highlight will be gone!
Alarm icon
Cool think and a bit deeper thinked idea.
If alarm is configured and ON - bell icon appars, there's yellow highlight at the left, background under hours/minutes will switch to... yellow! Also you will see hours/minutes of alarm with small highlight. YEY! You can see that alarm is ON and will ring ring ring more easly!
If alarm is configured but OFF - bell icon will disappear, but icon ON will be highlighted and small yellow bar will still be visable. Yellow background below hours/minutes will NOT be visable. So you know, alarm is configured but it's OFF.
If alarm isn't configured and it's OFF. Whole system will turn to off, no highlights, no bars at the left side, no hours/minutes of alarms visable. Clear information that there's no alarm at all.
DND icon
Some people likes to use DND mode while in work, running, driving a car or something. But sometimes you can forgot that you have DND enabled. Not anymore. Because this watchface shows you that DND is ON with big red icon and red bar at the left side.
Distance and PAI
Yes, you can see how much you traveled with distance numbers, but it only supports only legal measurement units - kilometers. Also there's PAI number, so you can see how healthy you live, or how unhealthy you like to be
Calendar and date
So far it only supports Polish, but in few days I will make English version for you, maybe some others. Depends on popularity because it takes some time to make such fonts visable on screen.
You can see day and date on screen and day is highlighted at the right side. So you can clearly see which day of week we have! Sunday and saturday are highlighted with different color - saturday with silver and sunday with red icon. Other days are simply highlighted with normal color.
Weather
Like in many watchfaces you can see type of weather, actual temperature and temperature during day + during night. Only legal measurement unit - Celsius - is supported for now.
And well. That's all for now. Here's small GIF how it looks and works like.
If you have any ideas, comments, questions - let me know! And if you think it's the best watchface you have seen, you can always pass me a beer using Paypal.
