Hi guys, I need your help, this is the message that I got when I try to compile mi design, I don´t know what to do to fix it, if you have any idea let me know, thanks!
Debug|Reading config...
Debug|Reading referenced images from 'B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1'
Trace|Loading resources for 2 'Background'
Trace|Loading resources for 2.1 'ImageBasic'
Trace|Loading image 0...
Trace|File B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\0000.png doesn't exists.
Trace|File B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\000.png doesn't exists.
Trace|File B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\00.png doesn't exists.
Trace|File B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\0.png doesn't exists.
Fatal|System.IO.FileNotFoundException: File referenced by index 0 not found.
en Resources.ImageLoader.LoadResourceForNumber(String directory, Int64 index)
en WatchFace.Parser.Utils.ResourcesLoader.LoadImage(Int64 index)
en WatchFace.Parser.Utils.ResourcesLoader.Process[T](T serializable, String path)
en System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid3[T0,T1,T2](CallSite site, T0 arg0, T1 arg1, T2 arg2)
en WatchFace.Program.WriteWatchFace(String outputDirectory, String outputFileName, String imagesDirectory, WatchFace watchFace)
Fatal|System.IO.FileNotFoundException: No se pudo encontrar el archivo 'B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\evangelion-tonytostado_packed.bin'.
Nombre de archivo: 'B:\01_FILES\_Escritorio\_Hobbies\Watchfaces\Exportados1\evangelion-tonytostado_packed.bin'
en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
en System.IO.FileInfo.get_Length()
en WatchFace.Program.PackWatchFace(String inputFileName)
en WatchFace.Program.Main(String[] args)
I got when I try to compile mi design [Mi Band]
TonyTostado
- Jackall Digital
- Has thanked: 1 time
- Been thanked: 14 times
It looks like you don't have the background image, which should be named "0000.png"
