Gtr2 watchfaces available in Amazfaces
Bloccato
mykpardinas
Messaggio da mykpardinas »
There are already watch faces available for gtr2 in the app but cant seem to install them.
It is stating invalid file when you use the notify for amazfit app.
Any workarounds for the issue
watcher
Messaggio da watcher »
After you download the file, do not open it immediately which gives you an error, you have to load it from the notify app, go to the home screen, scroll down to custom watchface ... scroll all the way to the right ... click on '' show more .. . '' under the dials you will find '' personalized watch-face (.bin) .... choose the .bin file to load from your smartphone ... it will tell you that it is valid and only then do the update.
Ciao!
Mozzakir
Messaggio da Mozzakir »
Which app?.....
Please eloborate
joebar78
Messaggio da joebar78 »
You need Notify for Amazfit & Zepp on the playstore
https://play.google.com/store/apps/deta ... l=fr&gl=US
But i was never able to load a WF with version 11.0.8 on the playstore.
I've downloaded the beta version 12.01 from apkmirror
https://apkmirror.com/apk/onezerobit/no ... k-download
Once i've installed this apk i was able to load a WF by selecting a bin file.
Hope it can help ;)
StepCounter
Messaggio da StepCounter »
joebar78 ha scritto: 23 gen 2021, 12:29
Hope it can help ;)
I believe this is due to a different implementation of the WatchfacesActivity class between 11.0.8 and 12.0.1.
Bloccato
Torna a “Closed topics”
