GTR 2 Watchfaces failed
Hi Guys I hoppe here is someone to help me. Here my Problem ,first I have installed the Amezfit Watchfaces App after that I start discovery and he found my watch and I put Apply.But now after that when it’s connected and it tap on set on watch always the information comes that I have to sync with zepp .I can do what I want alltime sync with zepp comes .I tried it also on three different phones .I hoppe you guys can help me.
- GIK-Team
- root
- Has thanked: 1162 times
- Been thanked: 278 times
viewforum.php?f=23eating wrote: 12 Jan 2021, 17:39Hi Guys I hoppe here is someone to help me. Here my Problem ,first I have installed the Amezfit Watchfaces App after that I start discovery and he found my watch and I put Apply.But now after that when it’s connected and it tap on set on watch always the information comes that I have to sync with zepp .I can do what I want alltime sync with zepp comes .I tried it also on three different phones .I hoppe you guys can help me.
- GIK-Team
- root
istickland
I have the same issue. Anyone managed to install a watch face successfully on the GTR2?
Download file.bin of your selected watchface ... After installing It with notify for amazfit
I have installed on my GTR2
ccolombo71
Notify for amazfit is only for Android. A solution for Iphone ?Dinodn wrote: 16 Jan 2021, 16:32Download file.bin of your selected watchface ... After installing It with notify for amazfit
-GAMER-
- Has thanked: 3 times
I've succesfully installed *.bin on iPhone via Amaztools app. Please download/update to the latest version of the app. Open *.bin file with GTR 2 watchface. You will see error like "the file can't be applied to your watch". After that please select "..." at the top of screen and select that this is Watchface. After that you will upload watchface to the GTR 2 and it will work without issue.ccolombo71 wrote: 16 Jan 2021, 21:14Notify for amazfit is only for Android. A solution for Iphone ?Dinodn wrote: 16 Jan 2021, 16:32Download file.bin of your selected watchface ... After installing It with notify for amazfit
ccolombo71
I try but after click on "..." I select Watchfaces and After is sent to watch I've an error and doesn't sync-GAMER- wrote: 16 Jan 2021, 22:33I've succesfully installed *.bin on iPhone via Amaztools app. Please download/update to the latest version of the app. Open *.bin file with GTR 2 watchface. You will see error like "the file can't be applied to your watch". After that please select "..." at the top of screen and select that this is Watchface. After that you will upload watchface to the GTR 2 and it will work without issue.ccolombo71 wrote: 16 Jan 2021, 21:14Notify for amazfit is only for Android. A solution for Iphone ?Dinodn wrote: 16 Jan 2021, 16:32Download file.bin of your selected watchface ... After installing It with notify for amazfit
istickland
Somehow this app did eventually install the new face I downloaded. I saw nothing but requests to sync, so gave up. Looked at my watch a while later and noticed it had managed to install the new watch face
ccolombo71
You are luckyistickland wrote: 17 Jan 2021, 11:22Somehow this app did eventually install the new face I downloaded. I saw nothing but requests to sync, so gave up. Looked at my watch a while later and noticed it had managed to install the new watch face
- mrlawrencelam
- Been thanked: 2 times
Installing AmazFaces watch faces:
1) Install AmazFaces app and also the AmazTools app.
2) Pair your GTR2/2e with AmazTools. For GTR-2e, select "GTR2".
3) In AmazFaces app, use the filter feature to display only watch faces compatible to your watch. For GTR-2e, select "GTR2". Select the watch face you wish to install, press the SHARE icon and send the file to AmazTools for syncing.
If you are getting "Generic Error" failure message repeatedly after many attempts, the storage might be full. Try deleting some existing watch faces and try again.
