[FIXED] Custom watch face crash T-Rex [T-Rex]
prolounge
Post by prolounge »
So I just started using the Editor yesterday, and I made a custom watch face from scratch.
I uploaded it to my account and downloaded it on my phone via the app.
I synced it with my T-rex, after the syncing bar finished, my watch notified that it synced successfully and then it froze. After a few seconds the watch restarted itself, but wouldn't boot and got stuck in an endless loop of booting, I also couldn't connect the phone with the watch.
So I had to put my watch on the charger, I was able to connect to my phone, and I synced the old custom watch face, and my phone could boot again.
So I was wondering, what makes my custom face crash the T-rex like that. Can someone review my face? Here's the link: amazfitwatchfaces. com/t-rex/view/2934
Thank you!
[UPDATE]
I found the problem and the solution.
Apparently I ignored the warning that the file exceeds 5.5MB and might not work.
After you run and compress .bin there should be no warning at all.
The solution is to put the T-Rex on the charger so it display the charging face instead of the normal watch face, then connect through Zepp and sync another working face.
ariajagatnata
Post by ariajagatnata »
I have a same problem
prolounge
Post by prolounge »
[UPDATE]
syams_74
Post by syams_74 »
Can anyone teach me to make my own watchface for amazfit t rex?
