Can't access watch face folder on my Stratos
wm8c
Post by wm8c »
Hi group, new user here as I just received my Stratos on Friday. I was trying to download some new watch faces for my watch which I did sucessfully to my PC but when I try to copy the .wfz files to the watchface folder on the watch, it wont work? The folder is locked and won't allow me to copy the files to it. What am I doing wrong? I couldn't find an answer here on the forum after a search which only gives me the instructions on how to do it but as I said, the watch won't let me copy the files into the folder. Please help...thanks
wm8c
Post by wm8c »
Is there no one in these forums or does no one have an answer
Has thanked: 1109 times
Been thanked: 267 times
WatchFace folder (without a dot at the beginning)?
wm8c
Post by wm8c »
I think maybe I didn't state my problem correctly. When I plug my watch into the computer, I can see the watchface folder. However, if I try to drag a watch face file from this forum into that folder, it's access is forbidden (locked). When I contacted Amazfit about this, the answer I got was "the watchfaces installed in the app are the only approved watchfaces for the watch and that folder is not accessible". So, they basically have locked that folder from access. So I guess I'm stuck for now.
wm8c
Post by wm8c »
Nope, I'm just an idiot. Was the problem of choosing the folder without the . in front of it...thanks GIK Team!
