How to install watchfaces (Amazfit X, Amazfit Band 5)
Moderatori: asoo, Internal error
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Messaggio da osmat »
Detailed instructions for installing custom watch faces on
Amazfit Band 5 and Amazfit X smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp
For a successful installation, you need to connect your gadget to a smartphone on Android with the Zepp app installed. You also need to have installed file manager and pre-download the watch face that you would like to set on your watch.
Installation
ll one of the stock watch faces available in Zepp
(if you have already installed one, you may skip this step).
Open the folder with the downloaded watch face in the file manager with the path:
Codice: Seleziona tutto
 /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
Go to any of these folders and find the .bin file. Copy the .bin file name.
Name example:
4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
Go to the custom watch face and rename it using the name of the standard watch face.
Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
Open the Zepp app and install the stock watch face, which file you replaced.
maxakash
Messaggio da maxakash »
will it work if I replace the image as well?
Will the new image be shown?
osmat
Admin
maxakash ha scritto: 23 nov 2020, 12:42
No preview image will most likely not change. But you can try it and share it with us here.
maxakash
Can someone please provide me the image of watch face which is to be replaced and its folder name ?
sobka
Messaggio da sobka »
Hi osmat ,
I downloaded 5 custom faces from this site and followed the instruction for adding them into Amazfit band 5.
They worked, however when I added 3 they took 3 spaces for custom bands. And I can not delete them, becasue they have no design, just grey backgroud and I can not select them to overwrite. I can not even sync any face from the Shop, becase I have to pick the face to overwrite, but I can not pick any, it is just impossible to made a pick :-)
Thanks for help
gerinhomd
Messaggio da gerinhomd »
Hello osmat .
The default whatch faces are note inside the folder, just the ones i downloaded from the store.
Thanks for help.
osmat
Admin
sobka ha scritto: 03 dic 2020, 10:04
Hi @osmat ,
Thanks for help
Delete the application data and install the standard watch faces
osmat
Admin
gerinhomd ha scritto: 04 dic 2020, 14:36
Hello @osmat .
Thanks for help.
It is them that need to be replaced.
sobka
osmat ha scritto: 04 dic 2020, 18:35
Hi @osmat ,
Thanks for help
Do you mean in app settings to wipe cache or wipe all data?
If I wipe all data, are my data saved on some cloud? I mean all my measerments (Heart beat, PA1, etc...)
osmat
Admin
sobka ha scritto: 05 dic 2020, 21:35
Hi @osmat ,
Thanks for help
Let everything stay on the server
saloca
Messaggio da saloca »
Hola no consigo comprender, pero si conecto mi amazfit x al ordenador no consigo ver el contenido del amazfi X, como en los otros modelos, es necesario algun programa en el ordenador para poder ver el contenido del amazfit X, si me podeis decir alguna pagina web donde pueda ver yo esto en español. gracias
Has thanked: 1155 times
Been thanked: 278 times
Messaggio da GIK-Team »
saloca ha scritto: 09 dic 2020, 07:13
You do not need to see the contents of the watch, all replacement operations need to be done in the application on the phone.
SandraMichael
Has thanked: 8 times
Messaggio da SandraMichael »
If you want to flash a custom watchface with the iPhone on the Amazfit X you can use the great AmazTools.
Version 1.2.4 of 6.1.2021 should now also work with the Amazfit X. I can't try it myself because I have the beta version. And you know: Never touch a running system! :)
Ultima modifica di SandraMichael il 08 gen 2021, 15:33, modificato 1 volta in totale.
alxleon2000
Messaggio da alxleon2000 »
SandraMichael ha scritto: 12 dic 2020, 12:49
But you need to ask the developer for the beta version.
how to ask the developer for the beta version for iPhone?
thanks
SandraMichael
alxleon2000 ha scritto: 29 dic 2020, 18:17
https://amaztools.app/help/
Under "I need help" you will find an email address.
papajim
Messaggio da papajim »
Amazfit X watchfaces are .png files. Replacing from .bin files is not working.
papajim
ΟΚ found it! I had to check all the folders to understand what was going on.
If you don't sync a watchface you get only the .png . I had to sync it first with the clock to download the .bin which then I can replace with one from here.
benjmiharris
Messaggio da benjmiharris »
Hi
Is there any way of uploading this watch face design using iOS?
Suhasggosavi
Messaggio da Suhasggosavi »
Watch face not getting changed saying synchronise the watch
jcunltd
Messaggio da jcunltd »
It does not work for me :(
replace the .bin and nothing .. you have to disconnect it from bluetooth or something like that, because I did it twice and nothing .. the one you download always loads :(
SandraMichael
benjmiharris ha scritto: 25 mar 2021, 19:46
Hi
Ilay82
Messaggio da Ilay82 »
Bei mir ging das mit dem installieren ganz leicht. Einfach auf die Datei drücken. Dann steht da, senden an Smartwatch.
Das Problem ist, ich konnte 2 runterladen, aber dann nix mehr. Kan man am Tag nur eine runterladen. Oder hat das damit nix zu tun?
Ich muss noch bis morgen warten, dann weiss ich es eventuell. Dann sind die 24 Stunden um.
fmenditto
Messaggio da fmenditto »
Hi, I have iphone with IOS 15. I can download watchfaces for amazfit X but when I try to send watchfaces to amazfit X with AmazTools i have an 0x10 error.
anyone have idea?
Darei
Messaggio da Darei »
I have Samsung with A12 and if i click to connect to amazfit, then said connected and after sync, button disappear and nothing happened. What i do wrong?
osmat
Torna a “Manuals and instructions”
