CUSTOM watch face problems and errors
umatej
Post by umatej »
Hi.
How can lift wrist to view info issue be fixed on custom watchface. I am using Digital5_B/W_24hr_UK watch face, https://amazfitwatchfaces.com/bip/view/?id=7326 and as soon i get into status menu on the watch, lift wrist function doesnt work anymore, screen doesnt lit up. Also the hearth rate option with measuring every 30min doesnt work.
How to prevent those kind of problems while creating custom watch faces?!
I really like amazfit bip for its loong battery life, great screen in sunlight and also cheap price and looks.
umatej
Post by umatej »
I found out that the watch face settings remain unchanged and lift to view info and continous heart rate measurements still work with custom watch face if you install .bin via mi fit app. Check method 1 for installing watch faces.
