Amazfit T-Rex Spare Strap Pin [T-Rex]
ReDDevilL
Post by ReDDevilL »
First,...Glad to Be Here !!! :D ;)
Own 3 Xiaomi - Huami Smart Watches Fitness Trackers ,....
T-Rex , Verge Lite, Mi Band 5 !
Got a question concerning my T-Rex Watch,...
As Already mentioned somewhere around here, someone asked about some spare parts ,
for the T-Rex ( more specific ) The Pin Tubes for The Straps !!!
No one seems to give a straight answer,...
It is not about the Exchange or Custom Colour Straps, “but” ,
about the Pins to Fasten The Straps!!!
Looked for it everywhere on the Net , ...
Amazfit Official Retailers, Online Sellers, Chinese or Hong Kong Suppliers ,...
No One,...But Absolute No One , Seems to have it ( The Small Pin ) ,...
No One , Sells It ,... No One Has It!!!
No One , Seems to Know , where it can be found , or bought ,...
It’ s Unbelievable ,...Such a Big Smart Watch Manufacturer ( 3-4rd in the world ) ,
and they don’t have or commercialise spare parts for their products, neither offer support ,
for it!!!
I have not loose it yet, “ but” in the eventuality that, will be needed , what should i, or, we do,...?!!!
Not wear them anymore ( Watch ,...) ?!!!
Tried even contacting other sellers , suppliers, or manufacturers,
from other marks or companies ,...
“Stucked” , with the same invariable answer,...
We don’t have it, we can not manufacture them,...
Now, my final Question,....
Where can be found and or bought, these “stupid” pins , that are so necessary,
in case they will needed ,...?!!!
Can anyone have a viable answer for it,...?!!!
I Repeat,....Not The 3rd Party Silicone, Leather, Metal, Textile Straps,....
“But”, The Tubular Pins , Screws used to Fasten The Straps to The Watch Itself ,...
They should look something like this ( these are for Garmin ),...
Also,.... What’s The Real Size (The Diameter and The Length,...)
Total Length seems to be 26mm ( at the end ), but the diameter,...?!!!
Anyway,... Hope that someone, or somebody, will give a decent answer, to the point,
and not sending us to buy, more straps ,...
Could they be replaced, by a different pin from other manufacturer , if the Amazfit they don’t seems to care about it,...?!,,
P.S. As They already were mentioned in here, ( The Spare Straps ),...
Does anyone knows if they exist , are commercialised , or produced officially by Amazfit ,...?!!!
And i’m not Talking about The Third Party Manufacturers or Sellers,...
The Amazfit Company Itself Officially Spare and Or Accessories !!!
Thank you,...
YOUR LIMITATION IS ONLY YOUR IMAGINATION
Mano1013
Post by Mano1013 »
En la página de compras china se vendes correas que incluyen los tornillos pasadores para este reloj en particular, tanto la correa como los pines de sujeción y 2 destornilladores vienen incluidos
ReDDevilL
Post by ReDDevilL »
Gracias, ... Por favor, envíeme un enlace de los minoristas en AliExpress donde encontrará estas correas con alfileres. ¡¡¡Estaba buscando y no pude encontrarlos !!!
Users browsing this forum: Google [Bot], Google Adsense [Bot], SGGage and 1 guest
