My watchfaces doesn't show battery
Bloccato
Luis00
Messaggio da Luis00 »
Hi, I don't know if this is the right place to create this topic but I have a problem with one of my watchface,
this one: https://amazfitwatchfaces.com/mi-band-4/view/16298
When I use it on my xiaomi mi band 4, I don't see the battery. Why?
Thank you!
Jackall Digital
Been thanked: 14 times
Messaggio da Jackall Digital »
Codice: Seleziona tutto
"Battery": {
      "BatteryConfig": {
        "BoxWidth": 0,
        "Alignment": 0,
        "Order": 0
      "Text": {
        "TopLeftX": 74,
        "TopLeftY": 4,
        "BottomRightX": 104,
        "BottomRightY": 22,
        "Alignment": "BottomRight",
        "Spacing": 0,
        "ImageIndex": 31,
        "ImagesCount": 10
      "Icon": {
        "X": 107,
        "Y": 4,
        "ImageIndex": 41,
        "ImagesCount": 10
This is just an example code. What you're missing is the BatteryConfig property(boxwidth, alignment, order), then it should work. You can use text or icon, you don't need to use both.
Luis00
Jackall Digital Thank you so much, it worked.
Bloccato
Torna a “Closed topics”
