How to create watchfaces for Bip S
mikebounds
Post by mikebounds »
Does anyone know how to create watchfaces for Bip S which include activity figures (steps, pulse, calories, distance) ?
As I understand, you can use online watchface editor at https://amazfitwatchfaces.com/editor/wa ... ditor/?bip to create watchfaces for Bip S, but it will not show any activity figures, but some users like sugojirou, Marselago and GIK-Team have managed to create faces for Bip S containing activity figures - does anyone know how?
I have also tried extracting one of the bip S bin files using AmazfitBipTools-1.0.3.1 https://bitbucket.org/valeronm/amazfitb ... downloads/, but it cannot extract the files (json and png files).
Mike
ntelas
Post by ntelas »
I am on the same boat. Did you find the solution?
Edit: Found it!
Milo
Post by Milo »
ntelas wrote: 05 Jun 2020, 15:42
Edit: Found it!
But did it work for you? I'm getting stuck when editing the JSON file to add the "number" thingy under certain activity's...
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
