watchface unreadable
fredu24230
Post by fredu24230 »
hello,
since i went under stratOS 2 a lot of watchface does not work anymore. there is only a black screen on the watch.
however, I put the files in the 'watchface' folder of the watch.
I am really disgusted because many do not work since this update.
If anyone has a solution ... thanks
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Watchface in .wfz format are fully compatible.
Give a link to those that you do not work we will check them.
fredu24230
All the Watchfaces were working on StratOS 1 but some have not worked since I installed version 2.
I think the problem comes from the Rom. How to remove this SratOS and return to the original Rom?
fredu24230
everything is back to normal after installing the original ROM. thanx
