T Rex new strap [T-Rex]
ova
Post by ova »
Do you can somebody advice where buy new watch strap.
I has been tried to look on lot of places on internet, but not successfully😥
V.I.T.
Post by V.I.T. »
I'm interested as well...
Burdei
Post by Burdei »
I get all my watch bands from
AliExpress dot com
Bullit
Post by Bullit »
😉 on Aliexpress is now aviaible!!! search this "strap band T-rex"
BigDaddy
Been thanked: 9 times
Post by BigDaddy »
| Samsung Galaxy S20 Ultra 5G | Samsung Galaxy Watch 3 BT 45mm | Amazfit Bip U Pro |
Kompica
Post by Kompica »
Rafel
Post by Rafel »
BigDaddy wrote: 26 Apr 2020, 18:11
Can't quote links...
Hi there.
Are those Casio straps T-rex compatible?
xeroxero
Post by xeroxero »
https://youtu.be/Z98JTH9JCdc
I was able to use the GST straps.
powaysteve
Post by powaysteve »
I can't translate the video that xeroxero recommended. What kind of tool and how do you remove the strap pins. I would like to put a metal strap on my T-Rex. It appears that the casio metal straps for the g-steel watches may fit. It that what you meant by GST strap? Thanks
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
powaysteve wrote: 20 May 2020, 19:47
Hi^^ It's the Casio strap sold by aliexpress : https://fr.aliexpress.com/item/4000606258464.html told by Kompica upper on this thread.
powaysteve
Does ayoe know where to purchase the screw tubes that hold the watch strap on? In changing the band I lost one screw and need to buy new ones (hopefully in the US to save shipping time) Thanks.
Magik933
Post by Magik933 »
HI, I bought bracelet from aliexpress (Kompica link). The watch is 0.5mm wider than the gap in bracelet but looks good after fitting.
ReDDevilL
Post by ReDDevilL »
As i know,...And search all ready on the Net ,
AliExpress, GearBest, Geekbuying, Officialy Amazfit Site, Different Other Sellers, ..
Officially Flagship Accessories ( Spare Straps , Tubular Pins ) , No One Have Them, No One Makes Them, They Don’t Exist,...😆😄😅😂
That’s it,...Live with it!!! 🤐😎
Still , have a chance for Some Third Party Custom Straps , On AliExpress or Online Chinese WebShops ,... They Seems OK ( QUA Quality and Design ) ,...
BEWARE ,...Take good care of the original pins, or you will wear the watch strapped at your
Arm with some rope , or cable ,...😂😅🤣
( THEY ARE NOWHERE TO BE FOUND , NEITHER FOR SALE OR MANUFACTURED,...)
My Two Cents,....
YOUR LIMITATION IS ONLY YOUR IMAGINATION
