Amazfit GTR 47mm problem with barometer and altimeter
JT2020
Post by JT2020 »
Hi to all,
I've had the Amazfit GTR 47mm for four months. From the beginning I have a problem with the pressure gauge and altimeter accuracy. The difference from the weather station values is from 40 to 90hPa and 50 to 200m.
I have a question, is there an application or procedure to calibrate a pressure sensor?
I'm sorry for my bad English
Maca12345
Post by Maca12345 »
Mám taky tento problém.
RositaaIsabelll
Post by RositaaIsabelll »
Hello! I've never had a problem with a smartwatch Xiaomi until now. It's the same with me as with you and I still can't find any solution... I have no idea how to calibrate the sensor. Have you found any solution yet?
