WatchFace freezes clock (SOLUTION)
999Nocturne
Post by 999Nocturne »
In case you have tested a WatchFace and it has undergone an infinite restart here is what to do:
1.Turn off the watch completely, so that it will not restart
2.Connect the charger to the watch
3. Now from the smartphone start the Amazfit app, the watch should connect
4.From the Amazfit app install an original WatchFace (Make sure you have deleted the Androis/data/com.huami.watch.hmwachmanager/files/watch_skin_local/ folder from your Smartphone)
5.Turn on the smartwatch
ast02
Post by ast02 »
The problem is that I cannot turn off the watch, screen is black andd the buttons are not responding...
PapaPet
Post by PapaPet »
ast02 wrote: 22 Feb 2020, 07:20
It is sufficient to connect the charger to the watch, the charging screen should be visible on the watch.
