T-Rex faces
T-Rex faces
Hello, I would like to know when you are going to include the spheres and the category of T-REX, I have it since day 23 and I am impatient, thank you very much for your work
- GIK-Team
- root
- Has thanked: 1161 times
- Been thanked: 278 times
We have already included a section on the site, and will soon add it to the applicationmaculi wrote: 27 Jan 2020, 19:00Hello, I would like to know when you are going to include the spheres and the category of T-REX, I have it since day 23 and I am impatient, thank you very much for your work
Are all the watch faces in a 24hr format and also the temp in celcius? I generally dont use military time and have no clue how to know what the temp is unless it is in farenheit. It would be nice to be able to change these features...
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
Setting units is in the application AmazfitZach607 wrote: 15 Feb 2020, 16:57Are all the watch faces in a 24hr format and also the temp in celcius? I generally dont use military time and have no clue how to know what the temp is unless it is in farenheit. It would be nice to be able to change these features...
Watch faces in structure are a set of pictures. You can ask the author of watch faces to make a dial with the units of measure you need.
I've been trying to install some watchface to my new T-Rex since yesterday and never succeed. I've downloaded the Apps to my iPhone and got it connected to my T-Rex. Everything seems to be working and I can reach 100% of Flashing firmware but after a short while it respond "something went wrong, please re-install again".
Can someone please help/
Thomas
Thomas
- osmat
- Admin
Sometimes the installation process may be interrupted. This happens if the screen of your phone turns off. We are working to fix this error.yht wrote: 29 Feb 2020, 12:38Hi,
Thomas
not working with my Trex. Syncing just stopped at 99,98% and say that Something went wrong. Even if my phone screen is still on
- osmat
- Admin
Try to restart the clock and try the installation again, also send a link to watch faceGurru44 wrote: 01 Mar 2020, 20:37not working with my Trex. Syncing just stopped at 99,98% and say that Something went wrong. Even if my phone screen is still on
I have this problem with all watchfaces available
- osmat
- Admin
Have you tried restarting the watch? Before installing, did you wait for synchronization with Amazfit?
Yep tried everything. I tried to change face with my older GTS and works without problem. So I dont know.osmat wrote: 02 Mar 2020, 10:23Have you tried restarting the watch? Before installing, did you wait for synchronization with Amazfit?
I have exactly the same problem. Did anyone manage to solve it? It happens on every watchface. I have an Iphone X. Maybe I am doing something wrong? I just need to sync the watchface on the app right? It comes to 99.7% and stops with the info that „something went wrong”. I’ve tries to reset all, delete the app etc-nothing helped.
I was wondering if ita possible to make each watch face compatible for everybody meaning 2 versions....1 in 24hr with km and 1 with 12hr with miles??? I havent tried to make a face yet but with a majority of the faces not geared towards the us I just might hop on board.
