Unable to replace the (big?) fresh clock faces (ie: Nixie) pls help!!!
Bloccato
Giobatta65
Messaggio da Giobatta65 »
Hi Guys
pls help me I dont understand ... first of all until today any watchface loaded without problem, now Im unable to load two faces (for the moment), like Nixie Watch https://amazfitwatchfaces.com/verge-lite/view/592 (I love it a lot!! I want it!!! :))
or, just for a test, Star Wars clock https://amazfitwatchfaces.com/verge-lite/view/576
Thats because are really big?
Sync is good (but takes a lot, 9' or more, a little bit...) but the face is not present.
Please note, before bother you all :), I have done these steps:
- Verge Lite resetted;
- uninstalled and reinstalled bot AmazFit and your app;
- cleaned Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local;
- re-installed and re-synced all the stock faces thru AmazFit;
- just in case: in Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local manually renamed and replaced the face using a PC;
- just in case: changed the local (phone and clock) from italian to english;
Stranger Things:
- from your App file is copyed correctly, for example, replacing first stock face (51832854d20fee8490feea7634c6ab4f) the .bin file is 504KB now, replacing by Nixie, is 1350KB;
- other fresh files in between loads correctly (like Illuminator - VL https://amazfitwatchfaces.com/verge-lite/view/591
no way: if I replace one or more of the 14 faces with Nixie (pls!pls!) face is not present (same for Star Wars): Verge Lite contains only the usual two (huge) default faces, third is not present, I have the stupid suspect faces too big are not loaded (however AmazFit says "sync succesfull") because of my slow bluetooth (maybe,I dont know, usually I'm on 3, max 4 minutes to sync any face), its normal TEN minutes to sync?
For your info I'm using firmware v.1.3.4.06 and the latest version of AmazFit and your app.
Any idea please? I love Nixie!! (a lot of thanks to the author).
Thanks in advance and sorry my english.
Giovanni
Giobatta65
OK definitely this nixie face dont work, i've tried to upload the face using brand new installation (every time resetting VL) on:
- Doogee S40 android 9 pie;
- cheap Mediacom tablet android 7;
- Huawei P Smart 2019 model;
- iPhone 6s too!!!
Sync succesfull on al the devices, no face on Verge Lite
How is possibile? And its in the top ten top... think no one wants to writer on this forum, neither if face Is not working
Any deas (ah ah ah)?
Bloccato
Torna a “Closed topics”
