Rolex Daytona Full Analog [ Steel or Pink Colour Choice ]
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
First I apologize for this Post.... received a complaint about "Stolen work" and undone "Credit" just wanna write how i Have done it step by step, and after you will judge me or not.
Reading time & Retrieve File : ~5 minute
Put some Music :
https://youtu.be/r2HyNclBxX4
ARTIST Crossfiyah
TITLE Rage
LABEL Afterlife Recordings
GENRE Hardcore
Now you are ready^^
Background comes from : https://drive.google.com/file/d/0B6xcK8 ... 9Ic1U/view
Where To find this link : https://forum.xda-developers.com/smartw ... k-t3276583
Silver colour : .img1687
Pink Colour : .img1701
Turquoise Colour : .img1673
For original graduation outer circle, Position of sphere, elements you can check it out to Wikimedia if you want to create it from scratch :
https://commons.wikimedia.org/wiki/File ... ematic.svg
Scaling this down will result on a 455*454 pixel size, let's manually put 454*454... there no difference to the eye.
Everything is aligned and perpendicular [ 3 - 6 - 9 - 12 Hour // position of small discs ]
Just Open your fresh background on Sash^^ Gui and verify yourself with Watch Hand, or Just draw 2 centered perpendicular line...
You Can cut out the small disc and use the Help of photoshop to align [ Purple line will appear once object you are moving are aligned with others, you have also Pixels differences that appear, so move a little to the left etc^^ It's a nice help^^ ] But here you don't have nothing to do... Perfectly align.
Sometimes, I just think about putting some Info on Pics like my name // Tags.... on an invisible way.... like the old Hex Method....
Have a secret.... Let's Hide it in a picture.... No It's not a Police Movie..... Basic Thing works..... Why Short message someone when you can simply talk with someone else this way..... the Underground way.
You can still open the PNG and do what you want with it.
On the original Background, original state untouch, there's no Metadata, Hidden Information.....
I make Faces for fun, and honnestly I don't want to waste my time making Hidden Tag on file or checking them, scanning them with tools, opening them with metadata tool or Hexadecimal editor.... i don't have time for this.
It's A face forum, not A rework of a scene release on Video File :lol: :lol: :lol:
Watchand :
Original picture comes from :
http://www.startimesupply.com/product/R ... -W-WH.html
But if you look closer, there's noise on it or rust.... let's clean out this sh*t on Photoshop.
A good advice on Photoshop that save you time, is to work always on 1 side left or right, have the real object you want to reproduce from scratch in front of you, or photo of real object. Why always on one side, becaus you can
->Duplicate Layer
->Transform : Horizontal Symetric
It will put the exact same Pixel // colour [ same object pixelperfect at the right place ] like you are watching you in a mirror, So if you work on background element just work on 1/4 of the watch, duplicate 3 time, Vertical 2 times and horizontal 1 time for symetric fonction. [ Select all the area on the duplicate layer and do the magic Symetric function, Tadaa^^ ]
Step 1:
Step 2 :
Step 3 & 4 :
Put the middle line in step 3
Put the White rectangle in step 4 [ Don't have rhe word in english, the thing that is white, the wider square ]
Don't put special effect now like shade, light reflexion..... Do it on Final stage, juste before finishing, because now you have to scale it
[ Scale + Detail + Special effect are not friends^^ ]
Scale :
Have a real watch in front of you or a good pic of it and do the magic.
Advice : Don't transform it to the real size using transform or Manual transform, scale it step by step with Image size [ Picture size, My photoshop software is in French, don't have the exact Menu item in my head, but dont' use transform. ]
If you use transform, You will lose detail on thing, after scaling with transform 3 times, your nice object in small size look like sh*t, precision and detail lost.
And now put the effect. [always resize your psd, not the png. [ PNG = Final state, on your PSD you can make them dynamic object also... :P ]
The Daytona posted is on V1.... as you can see, on Hour Hand and Minute, there is an 8 - 9 % difference size
It's better^^
I sugest you before this state , To duplicate once the final object, cut the part left // middle / right, save a copy of this PSD unscale somewhere before doing final adjustment [ because a safe copy is always nice to have ]
Reason : You have the hands in separate object, you can change colour easily, add pixel line to adjust how fat you want, do some modification, do what you want without losing time every time you want to re use your watch hands....
You lose time this time, but you gain time next time^^ [ Maybe it's time to write the sequel ]
Easy thing are easy to made... but when it's 2AM - 3AM, you start doing weird thing in front of screen, or start having bad idea.
Done some^^ I don't f**** second hand, only have it in final state [ but it can happen early......Only have to cut out shade, so it's not important.... go away for making me a cup of coffee.... and who was almost sleepy on my, keyboard.... my cat.... don't know how he managed to erase files..... or simply wipe my group on dungeon when I play the Cleric on MMO... Yes you can smile it happened..... and not 1 time. ]
Repeat this for Minute // Seconds // small hands for data.
All Hands related to this post [ Step 1 - 2 3 + Final state + Background work (add symetric object in 4 easy steps on a Daytona backgound... in this case add jewels )
https://drive.google.com/file/d/106XKgA ... HHQyI/view
Repeat with Minutes and second.
And now the Json File :
  "Background": {
    "Image": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 0
    "Preview": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 1
  "DaysProgress": {
    "AnalogMonth": {
      "OnlyBorder": false,
      "Color": "0x00000000",
      "CenterOffset": {
        "X": -117,
        "Y": -8
      "Image": {
        "X": 5,
        "Y": 44,
        "ImageIndex": 2
      "Sector": {
        "StartAngle": 3000,
        "EndAngle": 36000
    "UnknownField2": {
      "CenterOffset": {
        "X": 117,
        "Y": -8
      "Image": {
        "X": 5,
        "Y": 44,
        "ImageIndex": 2
      "Sector": {
        "StartAngle": 0,
        "EndAngle": 36000
  "Battery": {
    "Unknown4": {
      "CenterOffset": {
        "X": 0,
        "Y": 117
      "Image": {
        "X": 5,
        "Y": 44,
        "ImageIndex": 2
      "Sector": {
        "StartAngle": 0,
        "EndAngle": 36000
  "AnalogDialFace": {
    "Hours": {
      "CenterOffset": {
        "X": 0,
        "Y": 0
      "Image": {
        "X": 28,
        "Y": 162,
        "ImageIndex": 3
    "Minutes": {
      "CenterOffset": {
        "X": 0,
        "Y": 0
      "Image": {
        "X": 30,
        "Y": 195,
        "ImageIndex": 4
    "Seconds": {
      "CenterOffset": {
        "X": 0,
        "Y": 0
      "Image": {
        "X": 22,
        "Y": 221,
        "ImageIndex": 5
Now, I can grant "Credit" to someone who made something i Have not done myself, All source, All Hands in PSD, unscale and scaled state, I have provided a method to gain time [ if you didn't knew about this tip before ] to had things perfectly align the lazier way you can do.....
All I can Say.... now show me proof it's not my work.
I'm french, my english is broken, Hope you understand all
Reminder if you have not see it this post all Hands are Free to Use :
https://drive.google.com/open?id=106XKg ... f8gXTHHQyI
You can download them to check the proof, to work your skill, understand things.... Do what you want with them^^ and be Happy^^
The best advice I can give is sit down confortably, everything on your desk [ coffee + cookies ], setup your environment, always have the watch you want in front of you to check detail [ if you have a big big big LCD screen^^ It so funny to create thing ] and have fun^^
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
I had the same argue with a tag design. Altough i took parts of a code but did all the art myself. My advise: make designs the way you like, dont worry. First i hated it when people stole my work, but hey, maybe they could make it better? After all, this is not our job we make these faces for own fun.. And why want credits for a brand design.. Its only making you a target for brands for copyrights trouble. If you think some designs are only yours then people are really naive. Expect the expected..(this is not to you lordalpine, but the one who reported you XD) i Really respect that you had the patience to explain everything. My advise: keep doing what you like! And most important: make the faces you like and dont always listen to others!
For who wants to know: feel free to re-upload, edit or whatever one of my designs, dont need to credit. I make faces for fun and myself, just happen to post them here to easy upload them to my watch :-)
Lordalpine
Like the French Says^^ Bien Mal acquis ne profite jamais [ ill got ill spent ]
I always grant credit to someone who deserve it^^, All of you can check my watchface, Got nothing to hide, Got nothing to be ashamed.
Credit were given in Initial state... Does this person deserve it : Yes
IT was written : Ephemeral // under dev with credit.... and thank so much Hikashi for the new Fork "Fix Array"
After restarting from 0 from scratch from the Big Bang : ..:: No ::.. Because no part were used.
All the thing I have now / Own / or Owned were made with my hands... and Explaining to people How things are done is always a Pleasure for me... I'm not a teacher.... [ A Butcher in Real life.... Better skill with Knife in hand than a mouse.... and the funniest thing I am not a patient guy ].
The thing I prefer :
The Thing I have done "Myself"
Yeah Life Mode Story "Engaged" :
Even my house : https://imgur.com/gallery/0Hpfb
Or my Arcade Cabinet [ with free parts sleeping in the garage or find in the street like the screen ... It cost me like 70€ ] : https://i.imgur.com/Q51oAqk.png
