Python Environment // Pillow for Gui Tool & Py Tool [ Win 10 ]
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
If it can Help Someone^^ [ If i'm Right Of course ]
Let's Try to make it easy :
Download Python For Win 10...
So Go There : https://www.python.org/downloads/release/python-381/
And Choose : Windows x86-64 executable installer
Or type directly the URL Image
Install Python
You can check for all user if you want
Open a command line terminal in Windows [ as admin... Because Privilege // Elevation // Admin right // Lonely User // I'm God ]
Right click on start You will see something Command Line shell ( as admin )
Disclaimer : Opening an Admin terminal means you "know" it's not the time to make some erase "joke" thing if you know what I mean..... if you are helping a friend.... But are you a friend ??? :evil:
On this shell just type
pip install --upgrade pip
Type once again to confirm you have the last version
Last command line to write^^
pip install pillow
It will install pillow, and normally you can use the Python version of the gui tool or use all the command line Py Tools that exist [ Just check the command to pack and unpack, Syntax command can be different ]
Grab The Pytool that fit your need :
For example go there to find dpenddi's Fork of Loly Py Tool
https://github.com/amazfitbip/py_amazfit_tools/branches
Choose the "Fix Array" [ More option to design your watchface like analogic Hand for Data ]
Download the zip file and Unzip somewhere
An go inside this Unzipped folder in command line [ I won't explain how to do it... honnestly -.-" ]
How to know what command line to use... Simply invoke the "Help"
main.py -h
Once you have made the Python Installation it's easy to pack or unpack if the gui tool don't want to work...
To Unpack :
.\main.py --gtr 47 --file face.bin
So my file is named DaytonaV999.Bin.... so I change the face.bin by DaytonaV999.bin
main.py is on "E:\" Drive on folder Dev\Array
E:\dev\array>.\main.py --gtr 47 --file DaytonaV999.bin
Important thing : The Bin File DaytonaV999.bin is also on "Array" Folder which is the Unzipped Directory of the Tool
So in E:\Dev\array [ main py si here and also the Bin File.... easier, if you don't want to Type the Full location of your bin file.... and Because [ 95% of the reason ] I'm so lazy.... ]
To Pack
.\main.py --gtr 47 --file face/face.json
So In my case It will be :
E:\dev\array>.\main.py --gtr 47 --file DaytonaV999/DaytonaV999.json
If you're lazy^^ [like me] A gui editor is a nice tool to have : GTR_WatchFace editor for Windows by SashaCX75
You can find it here : viewtopic.php?f=29&t=1076&start=10
I only use it for the Json edit, personnally I prefer to Pack and Unpack in command line.
